GB for Speedometer drive bushing that stops leaks, Comes will all seals needed GB ENDS TOMORROW $52 for ALL |
Mikey914 |
Mar 12 2020, 10:07 AM
The rubber man Group: Members Posts: 12,667 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
What does this part do? Well is adds a second seal around the base of the opening in the transmission housing. Doing so adds a second barrier to help keep that annoying little drip on you garage floor.
We provide The bushing both outer seals and the internal seal You will need to re use your aluminum washer. Or we can sell you one, but these typically are not an issue. Just need 10 takers to get this price. Just to give you an idea the factory part alone is about $90, and it only has the one seal. SO who's in? Attached thumbnail(s) |
Mikey914 |
Apr 12 2020, 10:51 AM
I'll check it on my side, the front turn signal code has not been built yet. Blake will be doing that Monday. I will send out Tue for the headlight surrounds and hardware+.
914bub |
Apr 12 2020, 10:57 AM
Member Group: Members Posts: 433 Joined: 16-August 13 From: Modesto CA. Member No.: 16,260 Region Association: None |
I'll check it on my side, the front turn signal code has not been built yet. Blake will be doing that Monday. I will send out Tue for the headlight surrounds and hardware+. Mark Thanks. I was just trying to get everything set for when the GB codes drop for the other parts. |
Lo-Fi Version | Time is now: 16th May 2024 - 11:18 AM |
