GB for Speedometer drive bushing that stops leaks, Comes will all seals needed GB ENDS TOMORROW $52 for ALL |
Mikey914 |
Mar 12 2020, 10:07 AM
The rubber man Group: Members Posts: 12,667 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
What does this part do? Well is adds a second seal around the base of the opening in the transmission housing. Doing so adds a second barrier to help keep that annoying little drip on you garage floor.
We provide The bushing both outer seals and the internal seal You will need to re use your aluminum washer. Or we can sell you one, but these typically are not an issue. Just need 10 takers to get this price. Just to give you an idea the factory part alone is about $90, and it only has the one seal. SO who's in? Attached thumbnail(s) |
Mikey914 |
Apr 12 2020, 11:01 AM
This is what you should currently see at check out.
Seems to be working on the speedo at this time. I will be working with Blake Monday to build the codes for the other GBs' and will PM all on the threads that have signed up so if you wanted them you will be able to combine. I just got these listed up as fast as I could for those that wanted just these. Attached thumbnail(s) |
Lo-Fi Version | Time is now: 16th May 2024 - 07:02 AM |
