GB for Speedometer drive bushing that stops leaks, Comes will all seals needed GB ENDS TOMORROW $52 for ALL |
Mikey914 |
Mar 12 2020, 10:07 AM
The rubber man Group: Members Posts: 12,667 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
What does this part do? Well is adds a second seal around the base of the opening in the transmission housing. Doing so adds a second barrier to help keep that annoying little drip on you garage floor.
We provide The bushing both outer seals and the internal seal You will need to re use your aluminum washer. Or we can sell you one, but these typically are not an issue. Just need 10 takers to get this price. Just to give you an idea the factory part alone is about $90, and it only has the one seal. SO who's in? Attached thumbnail(s) |
maf914 |
Apr 21 2020, 08:16 AM
Not a Guru! Group: Members Posts: 3,049 Joined: 30-April 03 From: Central Florida Member No.: 632 Region Association: None |
Mark, I don't think I received the group buy code for the Speedometer Drive Bushing. Could you resend if possible? Thank you.
dax1969 |
Apr 22 2020, 03:14 AM
Member Group: Members Posts: 362 Joined: 10-March 14 From: belgium Member No.: 17,103 Region Association: None |
Lo-Fi Version | Time is now: 15th May 2024 - 11:59 PM |
