GB for Speedometer drive bushing that stops leaks, Comes will all seals needed GB ENDS TOMORROW $52 for ALL |
Mikey914 |
Mar 12 2020, 10:07 AM
The rubber man Group: Members Posts: 12,667 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
What does this part do? Well is adds a second seal around the base of the opening in the transmission housing. Doing so adds a second barrier to help keep that annoying little drip on you garage floor.
We provide The bushing both outer seals and the internal seal You will need to re use your aluminum washer. Or we can sell you one, but these typically are not an issue. Just need 10 takers to get this price. Just to give you an idea the factory part alone is about $90, and it only has the one seal. SO who's in? Attached thumbnail(s) |
Mikey914 |
Apr 27 2020, 11:43 PM
I did get some feedback that the second o-ring may have been slightly larger than it should have been. It is possible that some incorrectly sized orings got mixed in with these. I will be working on verifying the correct one tomorrow and will drop each of you a spare correct one, just in case you were affected by this so watch the mail you should see this week. I know there have been a number of successful installations so I'm hoping there were only a few that were affected, but I'd rather give everyone an extra just in case.
Sorry about that |
Lo-Fi Version | Time is now: 16th May 2024 - 05:51 PM |
