GB for Speedometer drive bushing that stops leaks, Comes will all seals needed GB ENDS TOMORROW $52 for ALL |
Mikey914 |
Apr 29 2020, 09:08 AM
The rubber man Group: Members Posts: 12,639 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
Yes this was us. New material Viton= much better.---No more difficult to install.
Look for manila envelopes 5x8 that we are sending out with new seals. I do apologize that my trying to improve the product created the problem. I have a tail cone of a tail shift that I have to check fit. On the we can push them in and make a tight seal. But we have the advantage of lots of light and better access. Those that have install them, there is no reason to pull them. You will have a VERY tight seal. It just went in much harder that it should have. |
Mikey914 |
Apr 29 2020, 09:10 AM
Heads up the coupon and the GB ends tomorrow Midnight Pacific
75914-L20C |
May 1 2020, 03:36 PM
It isn't what you drive, but how you drive that counts. Group: Members Posts: 55 Joined: 29-November 05 From: MN, USA Member No.: 5,204 Region Association: Upper MidWest |
Yes this was us. New material Viton= much better.---No more difficult to install. Look for manila envelopes 5x8 that we are sending out with new seals. I do apologize that my trying to improve the product created the problem. I have a tail cone of a tail shift that I have to check fit. On the we can push them in and make a tight seal. But we have the advantage of lots of light and better access. Those that have install them, there is no reason to pull them. You will have a VERY tight seal. It just went in much harder that it should have. Hey Mark - I got your new O-ring seal in the mail today. I checked my drive bushing and it has the brown seal, so I should replace it with the new one? My question is that the brown seal has an ID of about 26mm and the new one has an ID of about 21mm. Am I supposed to stretch it that much when I install it? |
Mikey914 |
May 1 2020, 03:41 PM
Yes this was us. New material Viton= much better.---No more difficult to install. Look for manila envelopes 5x8 that we are sending out with new seals. I do apologize that my trying to improve the product created the problem. I have a tail cone of a tail shift that I have to check fit. On the we can push them in and make a tight seal. But we have the advantage of lots of light and better access. Those that have install them, there is no reason to pull them. You will have a VERY tight seal. It just went in much harder that it should have. Hey Mark - I got your new O-ring seal in the mail today. I checked my drive bushing and it has the brown seal, so I should replace it with the new one? My question is that the brown seal has an ID of about 26mm and the new one has an ID of about 21mm. Am I supposed to stretch it that much when I install it? Yes, it is the correct size. The old seal "Black" will make it easier to install. |
SO.O.C914er |
May 1 2020, 03:46 PM
Senior Member Group: Members Posts: 1,236 Joined: 18-July 16 From: Mission Viejo Ca Member No.: 20,199 Region Association: Southern California |
Will you be mailing out a new seal to all of us who purchased? I have not tried mine yet. Still sitting on the work bench out of fear. (IMG:style_emoticons/default/lol-2.gif)
Mikey914 |
May 2 2020, 12:41 AM
Already done.
Lo-Fi Version | Time is now: 29th April 2024 - 04:49 AM |
