GB for Speedometer drive bushing that stops leaks, Comes will all seals needed GB ENDS TOMORROW $52 for ALL |
maf914 |
Mar 30 2020, 03:10 PM
I'll take one if the GB is still available. Thanks, Mark.
Mikey914 |
Mar 30 2020, 04:38 PM
The rubber man Group: Members Posts: 12,661 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
We went to pick up this last week and our vendor was closed. Just found this out. We have an alternate, but will not get til this til this week. SO not too late I got you on the list, but there are 4 ops on this so it takes a week to get it scheduled through. Thanks for the update @Mikey914 , works for me. And I hope I didn't come across as rushing you with my last post, just was wondering what kind of time frame we were looking at. Thanks for setting up the GB for these and stay safe! No problem, we had hoped that we would be shipping these this week. Just had not planned that our vendor would not have the raw materials and that we would be notified that we were not getting them instead of nothing. That doesn't work well when I'm at the day job as I assumed that things would follow a normal course of events, but they are down a few folks too so that didn't help. Ans yes no one is too late yet. Thanks to all Mark |
Mikey914 |
Apr 2 2020, 11:10 PM
Finally after much fuss I was able to go down and get the metal we needed.
Progress is being made Attached thumbnail(s) |
seanpaulmc |
Apr 6 2020, 06:40 AM
Member Group: Members Posts: 299 Joined: 6-December 16 From: Orlando, FL Member No.: 20,649 Region Association: South East States |
Still available? If so, will take one.
Thanks, |
Mikey914 |
Apr 6 2020, 03:22 PM
Yep will be this week also some other GB stuff coming together so will be able to combine.
914e |
Apr 7 2020, 12:05 AM
Member Group: Members Posts: 496 Joined: 21-February 20 From: Arizona Member No.: 23,951 Region Association: Southwest Region |
I'll take one too.
Niklas |
Apr 7 2020, 01:57 AM
Porsche 914 Sweden Group: Members Posts: 366 Joined: 20-June 09 From: Sweden - Skivarp Member No.: 10,488 Region Association: Scandinavia |
I take 2.
smj |
Apr 7 2020, 03:55 AM
"Dude, Steve from Berkeley." Group: Members Posts: 591 Joined: 28-August 05 From: Berkeley, CA Member No.: 4,691 Region Association: Northern California |
In (time) for 2. (IMG:style_emoticons/default/wink.gif)
bobboinski |
Apr 7 2020, 10:55 AM
Member Group: Members Posts: 198 Joined: 23-April 16 From: Petaluma Member No.: 19,929 Region Association: Northern California |
Would like to up my quantity to 2. (IMG:style_emoticons/default/irish914.jpg) (IMG:style_emoticons/default/white914.jpg)
Cornerlot |
Apr 8 2020, 07:18 AM
Member Group: Members Posts: 88 Joined: 4-June 16 From: New Braunfels, TX Member No.: 20,070 Region Association: Southwest Region |
I will take (1). Thanks.
MM1 |
Apr 8 2020, 07:45 AM
914 obsession continues Group: Members Posts: 608 Joined: 9-May 18 From: Thousand Oaks, CA Member No.: 22,105 Region Association: Southern California |
I'm in for one + washer (and probably whatever you add to the "kit")!
Mikey914 |
Apr 8 2020, 10:13 AM
I do that the Porsche washers. It is an add on. I didn't see the need to make a part that was completely reusable and not cosmetic.
I'm getting progress on these and I'm shooting to wrap up Friday and will start sending PMs. I also have a small hardware GB going that can easily be added in. |
Mikey914 |
Apr 11 2020, 11:16 AM
PMs sent to all so far. These are done and we are packing up now!
ndfrigi |
Apr 11 2020, 11:19 AM
Mark, One for me too. thank you!
914four |
Apr 12 2020, 08:33 AM
Senior Member Group: Members Posts: 510 Joined: 4-March 07 From: Rainbow City, Alabama Member No.: 7,582 Region Association: South East States |
+1 if it's not too late.
914bub |
Apr 12 2020, 10:43 AM
Member Group: Members Posts: 433 Joined: 16-August 13 From: Modesto CA. Member No.: 16,260 Region Association: None |
Is anybody else having a problem with the coupon code? I entered it exactly as it was sent to me and it says it's not a valid code? (IMG:style_emoticons/default/confused24.gif)
I put it in my cart and tried to apply the code so I was all set when I added the GB front turn signal parts but no dice. |
Mikey914 |
Apr 12 2020, 10:51 AM
I'll check it on my side, the front turn signal code has not been built yet. Blake will be doing that Monday. I will send out Tue for the headlight surrounds and hardware+.
914bub |
Apr 12 2020, 10:57 AM
I'll check it on my side, the front turn signal code has not been built yet. Blake will be doing that Monday. I will send out Tue for the headlight surrounds and hardware+. Mark Thanks. I was just trying to get everything set for when the GB codes drop for the other parts. |
Mikey914 |
Apr 12 2020, 11:01 AM
This is what you should currently see at check out.
Seems to be working on the speedo at this time. I will be working with Blake Monday to build the codes for the other GBs' and will PM all on the threads that have signed up so if you wanted them you will be able to combine. I just got these listed up as fast as I could for those that wanted just these. Attached thumbnail(s) |
DRPHIL914 |
Apr 12 2020, 01:27 PM
no problem for me, processed as expected. order placed , but now that i know there is a GB for headlight surrounds please hold and send in one package, i will be getting those as well.
Thanks, Phil |
Lo-Fi Version | Time is now: 15th May 2024 - 05:53 AM |
