GB for Speedometer drive bushing that stops leaks, Comes will all seals needed GB ENDS TOMORROW $52 for ALL |
Mikey914 |
Apr 12 2020, 04:02 PM
The rubber man Group: Members Posts: 12,665 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
I'll hold it. Codes for the Headlight surrounds will go out tomorrow. If anyone wants in a +1 on the thread gets you the code.
914bub |
Apr 12 2020, 04:21 PM
Member Group: Members Posts: 433 Joined: 16-August 13 From: Modesto CA. Member No.: 16,260 Region Association: None |
This is what you should currently see at check out. Seems to be working on the speedo at this time. I will be working with Blake Monday to build the codes for the other GBs' and will PM all on the threads that have signed up so if you wanted them you will be able to combine. I just got these listed up as fast as I could for those that wanted just these. Mark I got it to work. I'm going to hold off placing the order until the front lens and related parts codes are active. Thanks,Erik |
MidshipMadness |
Apr 13 2020, 12:23 PM
Newbie Group: Members Posts: 27 Joined: 28-March 20 From: Hudson, WI Member No.: 24,064 Region Association: None |
Hi Mikey,
I need one of your Speedometer drive bushings. Please PM me a code sir. Bill |
914sgofast2 |
Apr 13 2020, 02:15 PM
Senior Member Group: Members Posts: 616 Joined: 10-May 13 From: El Dorado Hills, CA Member No.: 15,855 Region Association: None |
Just tried to place my order but the Discount Code won’t work.
Mike D. |
DRPHIL914 |
Apr 17 2020, 09:14 PM
Did you say you would post a “how to” video for installing these, or will be self-evident as i tear into this?
@Mikey914 |
Mikey914 |
Apr 17 2020, 11:52 PM
Did you say you would post a “how to” video for installing these, or will be self-evident as i tear into this? @Mikey914 it's pretty self-evedent, but a video helps. mark |
maf914 |
Apr 21 2020, 08:16 AM
Mark, I don't think I received the group buy code for the Speedometer Drive Bushing. Could you resend if possible? Thank you.
dax1969 |
Apr 22 2020, 03:14 AM
Member Group: Members Posts: 362 Joined: 10-March 14 From: belgium Member No.: 17,103 Region Association: None |
Big Len |
Apr 22 2020, 06:40 AM
Senior Member Group: Members Posts: 1,747 Joined: 16-July 13 From: Edgewood, New Mexico Member No.: 16,126 Region Association: Southwest Region |
Guys, you sent an email with the group buy bill, but somehow I deleted it. I sent you an email telling you this several days ago, but no response. So add me to the list again, I guess.
Mikey914 |
Apr 22 2020, 07:53 AM
GB info sent and resent.
Mark |
Big Len |
Apr 22 2020, 03:36 PM
Got it and paid. Thank you so much.
Root_Werks |
Apr 23 2020, 08:45 AM
Village Idiot Group: Members Posts: 8,319 Joined: 25-May 04 From: About 5NM from Canada Member No.: 2,105 Region Association: Pacific Northwest |
Got mine yesterday along with other stuff I ordered. Thanks!
fiacra |
Apr 23 2020, 11:43 AM
Person.Woman.Man.Camera.TV Group: Members Posts: 325 Joined: 1-March 19 From: East Bay Region - California Member No.: 22,920 Region Association: Northern California |
Too late to get in on the GB? If not, I need one. Thanks!
PancakePorsche |
Apr 25 2020, 05:37 PM
Member Group: Members Posts: 236 Joined: 29-July 11 From: Southern California Member No.: 13,373 Region Association: None |
I will take one please.
What does this part do? Well is adds a second seal around the base of the opening in the transmission housing. Doing so adds a second barrier to help keep that annoying little drip on you garage floor. We provide The bushing both outer seals and the internal seal You will need to re use your aluminum washer. Or we can sell you one, but these typically are not an issue. Just need 10 takers to get this price. Just to give you an idea the factory part alone is about $90, and it only has the one seal. SO who's in? |
Rusty |
Apr 27 2020, 11:58 AM
I'd like one as well.
-R |
914bub |
Apr 27 2020, 09:15 PM
Anybody else have a problem with the install? After removing the original I cleaned up the bore and area around it. Greased both o rings on the new part but I can't get it to go into the bore past the second, smaller, o ring. Also my lip seal is installed backwards but I figured I'd let that go for now since I don't have a good way to pop it out so I can flip it.
(IMG:style_emoticons/default/confused24.gif) |
Mikey914 |
Apr 27 2020, 11:43 PM
I did get some feedback that the second o-ring may have been slightly larger than it should have been. It is possible that some incorrectly sized orings got mixed in with these. I will be working on verifying the correct one tomorrow and will drop each of you a spare correct one, just in case you were affected by this so watch the mail you should see this week. I know there have been a number of successful installations so I'm hoping there were only a few that were affected, but I'd rather give everyone an extra just in case.
Sorry about that |
infraredcalvin |
Apr 28 2020, 12:17 PM
Distracted Member Group: Members Posts: 1,515 Joined: 25-August 08 From: Ladera Ranch, CA Member No.: 9,463 Region Association: Southern California |
Ironically, mine just started leaking, any way I can jump in for one of these?
Thanks! |
Aerostatwv |
Apr 28 2020, 01:17 PM
Member Group: Members Posts: 117 Joined: 13-July 11 From: WV Member No.: 13,315 Region Association: MidAtlantic Region |
Still available? Thanks! I'll need 2.
eric914 |
Apr 28 2020, 08:46 PM
Member Group: Members Posts: 381 Joined: 28-January 04 From: Waynesville OH Member No.: 1,613 Region Association: Upper MidWest |
I did get some feedback that the second o-ring may have been slightly larger than it should have been. It is possible that some incorrectly sized orings got mixed in with these. I will be working on verifying the correct one tomorrow and will drop each of you a spare correct one, just in case you were affected by this so watch the mail you should see this week. I know there have been a number of successful installations so I'm hoping there were only a few that were affected, but I'd rather give everyone an extra just in case. Sorry about that Glad there is a root cause. Spent over an hour trying to install the new one before giving up and putting the old one back in . |
Lo-Fi Version | Time is now: 15th May 2024 - 06:29 PM |
