Back up light harness |
914e |
Mar 12 2020, 10:22 PM
Member Group: Members Posts: 496 Joined: 21-February 20 From: Arizona Member No.: 23,951 Region Association: Southwest Region |
Among other parts of my wire harness. I'm missing the wires that go to the reverse light switch in the transaxle. I am guessing there is not a plastic connector that holds the contacts, so I just need to find some of the bullet contacts and the rubber boot. My question is how is the wire routed so that it does not end up wrapped around the CV joint? I don't see anything on the body or the transaxle to secure the wire.
cary |
Mar 12 2020, 10:44 PM
Hard to explain. The new harnesses have a solid stiffener that keeps it arced up out of the way.
Hopefully Jeff will chime in and give you the 411. https://www.belmetric.com/bullet-connectors...mm-p-11391.html https://www.belmetric.com/bullet-connectors...mm-p-11392.html Off the top of my head can't remember which one. But I think its the 5mm. |
914e |
Mar 12 2020, 10:59 PM
Hard to explain. The new harnesses have a solid stiffener that keeps it arced up out of the way. Hopefully Jeff will chime in and give you the 411. https://www.belmetric.com/bullet-connectors...mm-p-11391.html https://www.belmetric.com/bullet-connectors...mm-p-11392.html Off the top of my head can't remember which one. But I think its the 5mm. Do you think something like a piece solid 14 gauge copper wire would work to keep it out of the way? |
cary |
Mar 12 2020, 11:19 PM
Its stiffer than 14, maybe 10. How about aluminium clothes line.
They sell it at Ace or Home Depot. Then heat shrink the ends. Then heat shrink over everything. |
Mikey914 |
Mar 12 2020, 11:56 PM
The rubber man Group: Members Posts: 12,661 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
Are you missing the entire harness?
It looks like this If it's as easy as just splicing the2 wires in. We make the angles tube to keep the clearance, but I have seen many without. Attached thumbnail(s) |
GregAmy |
Mar 13 2020, 07:23 AM
Advanced Member Group: Members Posts: 2,298 Joined: 22-February 13 From: Middletown CT Member No.: 15,565 Region Association: North East States |
Off the top of my head can't remember which one. But I think its the 5mm. Measured mine: 5mm. Mark do you sell these connectors? I'd like to get a couple without having to pay silly shipping for just those. You can talk me into buying some other stuff I've been eyeing. |
Lo-Fi Version | Time is now: 14th May 2024 - 12:14 PM |
