Fan not turning |
Fan not turning |
abes914 |
Mar 21 2020, 09:07 PM
Member Group: Members Posts: 366 Joined: 30-March 11 From: Long Beach Member No.: 12,880 Region Association: Southern California |
So I thought I had a problem with my alternator. Red light is on and alt not charging. Found out that my fan is not turning. Belt is on and engine runs fine. Is it time to drop the engine? Is it time to get another engine?
Thanks in advance. |
jsaum |
Mar 21 2020, 10:29 PM
Senior Member Group: Members Posts: 530 Joined: 12-June 07 From: Everett, WA Member No.: 7,809 Region Association: None |
It’s connected to the crankshaft on a hub with a keyway and a bolt. There’s three bolts holding it onto the hub. I would start checking there first.
porschetub |
Mar 21 2020, 11:13 PM
Check the belt tension /condition first before jumping ahead,your fan will always drive but your altenator needs the above to work right,make sure you buy the currect belt,sorry but have forgotten ,its more about the width which works right with the 914 altenator drive pulley.
Mark Henry |
Mar 22 2020, 09:11 AM
It’s connected to the crankshaft on a hub with a keyway and a bolt. There’s three bolts holding it onto the hub. I would start checking there first. (IMG:style_emoticons/default/agree.gif) If the fan isn't spinning you have a serious hub issue. It could be checked in car, but it's likely going to be coming out. The fan could lost it's bolts and sheared the pin, or a DAPO could have left the hub key out. Or the crank nose broke off, never heard of it happening in a car, but it has happened to T4 aircraft guys. |
Mark Henry |
Mar 22 2020, 09:22 AM
IronHillRestorations |
Mar 22 2020, 10:16 AM
I. I. R. C. Group: Members Posts: 6,716 Joined: 18-March 03 From: West TN Member No.: 439 Region Association: None |
I can't imagine the engine running, and the impeller not turning without making a serious noise
abes914 |
Mar 22 2020, 11:28 AM
Thank you everyone for the helpful advice. The belt is the right size and properly installed. The issue started after I got back from our family vacation a few months ago. I asked a friend to stop by our house on weekends and water the plants and warm up the cars so battery won’t go bad. He don’t recall any loud noise. I’ll get the engine out one of this weekends and (IMG:style_emoticons/default/sawzall-smiley.gif) (IMG:style_emoticons/default/smash.gif) (IMG:style_emoticons/default/beer3.gif) (IMG:style_emoticons/default/beer3.gif) (IMG:style_emoticons/default/beer3.gif)
jsaum |
Mar 22 2020, 03:00 PM
Can use a cell phone and take a picture of the center of the fan? Here’s a few shots of the crank with the hub and keyway. You should be able to reach down inside the fan to feel if the three bolts are still in place. There’s also a shear pin on the hub.
Attached thumbnail(s) |
Mark Henry |
I can't imagine the engine running, and the impeller not turning without making a serious noise (IMG:style_emoticons/default/agree.gif) Thank you everyone for the helpful advice. The belt is the right size and properly installed. The issue started after I got back from our family vacation a few months ago. I asked a friend to stop by our house on weekends and water the plants and warm up the cars so battery won’t go bad. He don’t recall any loud noise. I’ll get the engine out one of this weekends and (IMG:style_emoticons/default/sawzall-smiley.gif) (IMG:style_emoticons/default/smash.gif) (IMG:style_emoticons/default/beer3.gif) (IMG:style_emoticons/default/beer3.gif) (IMG:style_emoticons/default/beer3.gif) Buy a couple of battery tender/chargers. (IMG:style_emoticons/default/shades.gif) |
jsaum |
Mar 22 2020, 03:02 PM
Crank, keyway and fan.
GregAmy |
Mar 22 2020, 03:15 PM
Advanced Member Group: Members Posts: 2,284 Joined: 22-February 13 From: Middletown CT Member No.: 15,565 Region Association: North East States |
Whoa, subscribing for this one...
abes914 |
Mar 22 2020, 06:14 PM
jsaum |
Mar 22 2020, 06:40 PM
Ok so the three bolts are in place you definitely need to drop the engine to see what’s going on. The center cone pops off and the bolt that holds the hub on is behind it.
Superhawk996 |
Mar 22 2020, 06:50 PM
914 Guru Group: Members Posts: 5,778 Joined: 25-August 18 From: Woods of N. Idaho Member No.: 22,428 Region Association: Galt's Gulch |
Be forewarned, that hub held by the center bolt sometimes takes a hub puller to get it off the taper.
Might want to start by just removing the 3 bolts that hold the fan to the hub and then see what you can see. None of this will be easy or fun to do with the engine in the car. Per your previous comment, best to drop the engine. |
euro911 |
Mar 22 2020, 06:58 PM
Retired & living the dream. God help me if I wake up! Group: Members Posts: 8,848 Joined: 2-December 06 From: So.Cal. & No.AZ (USA) Member No.: 7,300 Region Association: Southern California |
Definitely sounds like something with the hub/crank key is the cause, Abe.
With the right tools, you can remove the fan and inspect everything. I'd recommend getting an inspection camera, either a stand alone from Harbor Fright, or one that works with a 'schmart fone' (IMG:style_emoticons/default/idea.gif) (IMG:style_emoticons/default/popcorn[1].gif) |
ndfrigi |
Mar 22 2020, 07:36 PM
GregAmy |
Mar 22 2020, 10:29 PM
Yuck
abes914 |
Apr 20 2020, 04:17 PM
Got the engine out yesterday. I think the woodruff key got flattened out.
GregAmy |
Apr 20 2020, 04:26 PM
That's....unusual.
But if the crank is good, an easy fix. |
abes914 |
Apr 20 2020, 05:01 PM
Lo-Fi Version | Time is now: 5th May 2024 - 03:44 AM |
