NOS Alfa Brembo Aluminum 3" Calipers, Any Interest? |
914Sixer |
Mar 22 2020, 08:15 AM
914 Guru Group: Members Posts: 8,876 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
Found some NOS Alfa calipers. Anybody need some? Going to be about $650 a pair.
Attached thumbnail(s) |
pete000 |
Mar 22 2020, 10:29 AM
WOW, NICE !
B2524 |
Mar 22 2020, 11:04 AM
It's a sickness. Group: Members Posts: 72 Joined: 12-November 11 From: Outside Paso Robles CA Member No.: 13,776 Region Association: Northern California |
Modified for vented rotors?
Superhawk996 |
Mar 22 2020, 11:54 AM
914 Guru Group: Members Posts: 5,779 Joined: 25-August 18 From: Woods of N. Idaho Member No.: 22,428 Region Association: Galt's Gulch |
Modified for vented rotors? Intersted. When you say NOS -- How old? Are the seals good or will they be dry and brittle from sitting 30 years? Previously installed on any other car? I'd want the version for solid rotors. Looking for stright up bolt on for 3" struts. |
914Sixer |
Mar 22 2020, 02:38 PM
These are for vented rotors. To the best of my knowledge none were made for solid rotors. Guessing you could take out spacers and use new bolts. Brand new parts , no way of knowing manufacture date. Parts are not in US.
Superhawk996 |
Mar 22 2020, 03:56 PM
Mar 22 2020, 04:34 PM
914-6 GT in waiting Group: Members Posts: 19,255 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
excellent price. I bet they will be gone quickly on earlySreg
Alain V. |
Mar 22 2020, 06:10 PM
Member Group: Members Posts: 161 Joined: 15-March 13 From: Kansas Member No.: 15,655 Region Association: None |
bdstone914 |
Mar 22 2020, 06:20 PM
bdstone914 Group: Members Posts: 4,515 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
@Superhawk996
@914Sixer Mar 22 2020, 01:38 PM' post='2796516'] These are for vented rotors. To the best of my knowledge none were made for solid rotors. Guessing you could take out spacers and use new bolts. Brand new parts , no way of knowing manufacture date. Parts are not in US. [/quote] Seal kits are cheap and easy to install. Yes you can remove the spacers for use on solid rotors but may need shorter bolts as they use partially threaded bolts. With spacers removed the short bolts work in place of the long bolts. Bolts a common cap head 12.8 grade bolt. I think these only work on late struts unless you machine the ears. |
Superhawk996 |
Mar 22 2020, 06:58 PM
[quote name='bdstone914' date='Mar 22 2020, 08:20 PM' post='2796585']
@bdstone914 Thanks - Maybe that is what I saw somewhere. Good point on the seals. If the caliper had to be split to remove the spacer, at that point the seals are a cinch to replace. |
B2524 |
Mar 22 2020, 07:14 PM
Any idea who makes these? Or where?
They don’t say Brembo. |
bdstone914 |
Mar 22 2020, 07:31 PM
@B2524
date='Mar 22 2020, 06:14 PM' post='2796598'] Any idea who makes these? Or where? They don’t say Brembo. [/quote] Some of the Alfa calipers do not have Brembo on them. |
914forme |
Mar 23 2020, 06:25 PM
But Brembo made them. It is a great price.
914forme |
914Sixer |
Mar 24 2020, 06:25 AM
Deal fell through, not able to purchase.
Lo-Fi Version | Time is now: 6th May 2024 - 02:04 AM |
