Jacking point damage? |
Biggles |
Mar 25 2020, 10:00 AM
Member Group: Members Posts: 191 Joined: 5-September 13 From: UK Member No.: 16,353 Region Association: England |
I've noticed that the front jacking points on my car aren't level, and wondered if they've gone up as the car has been lifted - thoughts? It all seems solid.
Attached thumbnail(s) |
SirAndy |
Mar 25 2020, 10:15 AM
Resident German Group: Admin Posts: 41,601 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
They are crooked because those aren't jacking points!
There is noting solid on the other side, using them as jacking points means you are deforming your floorpan. (IMG:style_emoticons/default/shades.gif) |
Biggles |
Mar 25 2020, 10:29 AM
They are crooked because those aren't jacking points! There is noting solid on the other side, using them as jacking points means you are deforming your floorpan. (IMG:style_emoticons/default/shades.gif) Ok not good. Thanks. I had used a reference on the world referencing round 'donuts' that were safe to jack on - evidently not! What purpose do those areas serve ? So where is good to Jack up the car? |
dr914@autoatlanta.com |
Mar 25 2020, 10:37 AM
914 Guru Group: Members Posts: 7,809 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None |
jack under the engine mounting bar, or the front cross member, these are to rest jack stands with pieces of plywood to cushion the jack stand from the donut
Biggles |
Mar 25 2020, 11:13 AM
Cheers George. No engine mounting bar. It's a 6. I've been jacking on the rear donuts or on the trailing arm pick up points at the rear - no good?
jack under the engine mounting bar, or the front cross member, these are to rest jack stands with pieces of plywood to cushion the jack stand from the Attached thumbnail(s) |
Lo-Fi Version | Time is now: 18th April 2024 - 11:16 AM |
