Jacking point damage? |
Biggles |
Mar 25 2020, 10:00 AM
Member Group: Members Posts: 191 Joined: 5-September 13 From: UK Member No.: 16,353 Region Association: England |
I've noticed that the front jacking points on my car aren't level, and wondered if they've gone up as the car has been lifted - thoughts? It all seems solid.
Attached thumbnail(s) |
drem914 |
Mar 25 2020, 06:49 PM
Senior Member Group: Members Posts: 1,026 Joined: 16-May 08 From: Trabuco Canyon, CA Member No.: 9,062 Region Association: Southern California |
If those are not where we are suppose to jack the car up from, then how are we supposed to use a quick jack? I have one specifically so I don't have to use a single side lift jack to lift the car up. So much simpler to use than jack stands and a shop jack.
@cuddy_k ? |
iankarr |
Mar 26 2020, 12:10 AM
The wrencher formerly known as Cuddy_K Group: Members Posts: 2,471 Joined: 22-May 15 From: Heber City, UT Member No.: 18,749 Region Association: Intermountain Region |
If those are not where we are suppose to jack the car up from, then how are we supposed to use a quick jack? I have one specifically so I don't have to use a single side lift jack to lift the car up. So much simpler to use than jack stands and a shop jack. @cuddy_k ? I've always used the donuts...though with a quick jack the load is equally spread over the 4 of them. I suppose you could use the QJ pinch weld blocks and lift from the rockers, but you'd need to remove the rocker covers to keep them from getting bent. |
Lo-Fi Version | Time is now: 19th April 2024 - 04:51 PM |
