Jacking point damage? |
Biggles |
Mar 25 2020, 10:00 AM
Member Group: Members Posts: 191 Joined: 5-September 13 From: UK Member No.: 16,353 Region Association: England |
I've noticed that the front jacking points on my car aren't level, and wondered if they've gone up as the car has been lifted - thoughts? It all seems solid.
Attached thumbnail(s) |
drem914 |
Mar 25 2020, 06:49 PM
Senior Member Group: Members Posts: 1,027 Joined: 16-May 08 From: Trabuco Canyon, CA Member No.: 9,062 Region Association: Southern California |
If those are not where we are suppose to jack the car up from, then how are we supposed to use a quick jack? I have one specifically so I don't have to use a single side lift jack to lift the car up. So much simpler to use than jack stands and a shop jack.
@cuddy_k ? |
iankarr |
Mar 26 2020, 12:10 AM
The wrencher formerly known as Cuddy_K Group: Members Posts: 2,471 Joined: 22-May 15 From: Heber City, UT Member No.: 18,749 Region Association: Intermountain Region |
If those are not where we are suppose to jack the car up from, then how are we supposed to use a quick jack? I have one specifically so I don't have to use a single side lift jack to lift the car up. So much simpler to use than jack stands and a shop jack. @cuddy_k ? I've always used the donuts...though with a quick jack the load is equally spread over the 4 of them. I suppose you could use the QJ pinch weld blocks and lift from the rockers, but you'd need to remove the rocker covers to keep them from getting bent. |
drem914 |
Mar 26 2020, 10:02 PM
If those are not where we are suppose to jack the car up from, then how are we supposed to use a quick jack? I have one specifically so I don't have to use a single side lift jack to lift the car up. So much simpler to use than jack stands and a shop jack. @cuddy_k ? I've always used the donuts...though with a quick jack the load is equally spread over the 4 of them. I suppose you could use the QJ pinch weld blocks and lift from the rockers, but you'd need to remove the rocker covers to keep them from getting bent. For now I'll stick with the donuts. at most each is carrying 500 lbs. |
Lo-Fi Version | Time is now: 20th April 2024 - 08:30 AM |
