frostyf |
Member ![]() ![]() Group: Members Posts: 155 Joined: 27-March 14 From: VA 23455 Member No.: 17,168 Region Association: MidAtlantic Region ![]() ![]() |
Wanted to ask fro some advice from those who know.
My right rear caliper (4 stud stock 73 914 wheel) has started leaking. I've recently adjusted the venting distance whilst repairing the handbrake/ebrake. I've ordered two rebuild seal kits but wondered if anyone knows where to get replacement pins and the spring spreader clip. I've looked online and there seem to be plenty for front calipers? Are they the same, are the front pins interchangeable with the rear? Thank you in advance, Nick |
Cairo94507 |
Michael ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,380 Joined: 1-November 08 From: Auburn, CA Member No.: 9,712 Region Association: Northern California ![]() ![]() |
Call Eric Shea at PMB Performance in Utah. He is the answer to all of your brake needs and a whole lot me too. https://www.pmbperformance.com/catalog.html (IMG:style_emoticons/default/beerchug.gif)
frostyf |
Thanks for the steer, I emailed Eric and he came straight back to me. I had already bought two refurb kits from Pelican, but wish I'd gone straight to PMB.
One question I've still got is where to source the Rebe R5 tool to remove the caliper fasterners? Does anyone know where to source one of these? Looking at Eric's refurb film it says to avoid using the Torx sets as they can damage the fasterners. Eric said the replacements are about $15 each. Can anyone advise on where to find these online? Thank you, Nick Call Eric Shea at PMB Performance in Utah. He is the answer to all of your brake needs and a whole lot me too. https://www.pmbperformance.com/catalog.html (IMG:style_emoticons/default/beerchug.gif) |
mepstein |
914-6 GT in waiting ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 19,963 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region ![]() ![]() |
I got mine on Amazon or eBay. I can’t remember.
@frostyf |
914e |
Member ![]() ![]() Group: Members Posts: 497 Joined: 21-February 20 From: Arizona Member No.: 23,951 Region Association: Southwest Region ![]() ![]() |
Is it Rebe or Ribe? Summit racing has Ribe bits.
davep |
914 Historian ![]() ![]() ![]() ![]() ![]() Group: Benefactors Posts: 5,290 Joined: 13-October 03 From: Burford, ON, N0E 1A0 Member No.: 1,244 Region Association: Canada ![]() ![]() |
Ribe! Unless you are mechanically highly skilled, let PMB do the refurb. It takes several special tools and lots of experience to do a rebuild properly. Even then, the replated parts that PMB uses are not available to the home rebuilder.
The pins and spreaders are nearly unique, so finding them is very hard. The most likely source of leaks is from the O-rings on the adjusters. The outer one is very tricky to replace; I use a special tool for that one. Sure, in the video it looks easy, but that is in he hands of an expert. So far I am just an ex-squirt with 45 years of experience fixing them. Oh yeah. If you are going to use the Ribe bit, use it only to hold the head of the bolt and turn the nuts. |
Tbrown4x4 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 707 Joined: 13-May 14 From: Port Orchard, WA Member No.: 17,338 Region Association: None ![]() ![]() |
If you are mechanically inclined, it's not too bad, but you need to be able to transform this pile of parts back into a working caliper:
(IMG:http://www.914world.com/bbs2/uploads_offsite/i.imgur.com-17338-1585220261.1.jpg) If you have any reservations, send it to Eric. |
Lo-Fi Version | Time is now: 11th July 2025 - 02:20 AM |
