3.2 to 3.4 Pros-Cons, Opinions/ Options |
Coondog |
Mar 25 2020, 09:40 PM
Advanced Member Group: Members Posts: 2,089 Joined: 24-September 15 From: Apple Valley Calif Member No.: 19,195 Region Association: Southern California |
Been thinking about this for a while as I am halfway there already. Don’t get me wrong 212 RWHP is nice but there always more on the table to be had and Steve’s 3.2 kicks my ass off the line every time..... (IMG:style_emoticons/default/blink.gif) It’s his 915 tranny.... (IMG:style_emoticons/default/driving.gif)
-964 cams already installed -Big bore Throttle Body needed -98mm piston and cylinders needed -1 5/8" exhaust already installed -Custom chip would have to get remapped. Not changing Motronic system and not going duel plug. Opinions and options please. |
mepstein |
Mar 26 2020, 05:50 AM
914-6 GT in waiting Group: Members Posts: 19,238 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
I would do it to an engine that needs an overhaul but not to a good running engine. Way too much money for little return.
Mark Henry |
Mar 26 2020, 07:55 AM
I would do it to an engine that needs an overhaul but not to a good running engine. Way too much money for little return. (IMG:style_emoticons/default/agree.gif) Only option to me would be buy another core, build the engine you want and sell the existing running engine. Buy in would suck but likely cheaper in the long run. I build 996 engines, LN 3.4 to 3.8 JE piston upgrade, so that's a 400cc increase, a lot of guys expect a big increase in HP and get disappointed when I tell them about 40 HP if they're lucky. |
mepstein |
Mar 26 2020, 09:34 AM
I would do it to an engine that needs an overhaul but not to a good running engine. Way too much money for little return. (IMG:style_emoticons/default/agree.gif) Only option to me would be buy another core, build the engine you want and sell the existing running engine. Buy in would suck but likely cheaper in the long run. I build 996 engines, LN 3.4 to 3.8 JE piston upgrade, so that's a 400cc increase, a lot of guys expect a big increase in HP and get disappointed when I tell them about 40 HP if they're lucky. Yes. With what you have, 10-20hp would be the increase for all that work and money. What you said is telling. "It’s his 915 tranny...." I have one that is getting rebuilt. It's an early mag case with mechanical speedo and a much shorter final drive. It won't be a highway cruiser but should be fun around town. |
Steve |
Mar 26 2020, 10:02 AM
914 Guru Group: Members Posts: 5,569 Joined: 14-June 03 From: Orange County, CA Member No.: 822 Region Association: Southern California |
I would do it to an engine that needs an overhaul but not to a good running engine. Way too much money for little return. (IMG:style_emoticons/default/agree.gif) Only option to me would be buy another core, build the engine you want and sell the existing running engine. Buy in would suck but likely cheaper in the long run. I build 996 engines, LN 3.4 to 3.8 JE piston upgrade, so that's a 400cc increase, a lot of guys expect a big increase in HP and get disappointed when I tell them about 40 HP if they're lucky. Yes. With what you have, 10-20hp would be the increase for all that work and money. What you said is telling. "It’s his 915 tranny...." I have one that is getting rebuilt. It's an early mag case with mechanical speedo and a much shorter final drive. It won't be a highway cruiser but should be fun around town. My 915 gearbox is a stock 1986 with 8:31 ring and pinion. Taller gears versus an early 7:31 915 Much nicer not having to shift as much compared to a 914 gear box. |
Lo-Fi Version | Time is now: 25th April 2024 - 12:01 AM |
