3.2 to 3.4 Pros-Cons, Opinions/ Options |
Coondog |
Mar 25 2020, 09:40 PM
Advanced Member Group: Members Posts: 2,089 Joined: 24-September 15 From: Apple Valley Calif Member No.: 19,195 Region Association: Southern California |
Been thinking about this for a while as I am halfway there already. Don’t get me wrong 212 RWHP is nice but there always more on the table to be had and Steve’s 3.2 kicks my ass off the line every time..... (IMG:style_emoticons/default/blink.gif) It’s his 915 tranny.... (IMG:style_emoticons/default/driving.gif)
-964 cams already installed -Big bore Throttle Body needed -98mm piston and cylinders needed -1 5/8" exhaust already installed -Custom chip would have to get remapped. Not changing Motronic system and not going duel plug. Opinions and options please. |
live free & drive |
Mar 26 2020, 01:53 PM
Member Group: Members Posts: 154 Joined: 29-June 16 From: New Hampshire Member No.: 20,159 Region Association: None |
Try Sal Carcellers fuel injection/chip mod with MAF. There is a lot to read up on Sal on Pelican beyond the link below too.
He can adjust the chip maps to your 964 cams, Ben's headers, and octane you want to run (also method of oil cooling). http://forums.pelicanparts.com/porsche-911...stem-3-2-a.html you might be looking at 250-260hp I think the whole thing with custom tune cost ~$2K, probably cheaper than cracking open the case. I also don't think he will help you if your engine is not running right until you get the basics sorted. |
mepstein |
Mar 26 2020, 02:02 PM
914-6 GT in waiting Group: Members Posts: 19,239 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
Try Sal Carcellers fuel injection/chip mod with MAF. There is a lot to read up on Sal on Pelican beyond the link below too. He can adjust the chip maps to your 964 cams, Ben's headers, and octane you want to run (also method of oil cooling). http://forums.pelicanparts.com/porsche-911...stem-3-2-a.html you might be looking at 250-260hp I think the whole thing with custom tune cost ~$2K, probably cheaper than cracking open the case. I also don't think he will help you if your engine is not running right until you get the basics sorted. Sal has a great system and If I stay motronic, I will buy it. It's ~$2K for his custom MAF, injectors, computer and chip but you still need dyno time to tune it. He sends you updated tune's as you work the engine on the dyno. The last 5% always costs the most and there's a bit of irony because as you make more power from the engine, the 914 trans becomes more of an issue. |
Tdskip |
Mar 27 2020, 06:30 PM
Advanced Member Group: Members Posts: 3,684 Joined: 1-December 17 From: soCal Member No.: 21,666 Region Association: None |
The last 5% always costs the most and there's a bit of irony because as you make more power from the engine, the 914 trans becomes more of an issue. ^^^^^^ This Unless you have a surplus of time and money not sure it is worth it. That said - if you really want to do it then do it and have fun. |
Lo-Fi Version | Time is now: 25th April 2024 - 08:52 PM |
