FS GT oil line to 911 t-stat oil lines |
mb911 |
Mar 26 2020, 11:04 AM
914 Guru Group: Members Posts: 6,818 Joined: 2-January 09 From: Burlington wi Member No.: 9,892 Region Association: Upper MidWest |
What you get is the 2 stainless elbows, the long -12an line with fittings, the short oil line with AN fittings and the adapters for every thing I am offering these at just about cost. If you look up the fittings, lines,etc separately you will see its about a wash.
The price $ 430 shipped.. Was hoping to do it a bit cheaper but it's the best I can do buying AN fittings and hose at retail. |
colingreene |
Mar 26 2020, 08:05 PM
Senior Member Group: Members Posts: 729 Joined: 17-October 13 From: Southern California Member No.: 16,526 Region Association: Southern California |
So my question is If i have the factory 914-6 oil line off the case but plan on running the front mount cooler with the thermostat is the oil line i have not needed.
I never have been able to find a diagram of what this system would look like finished, admittedly I never did put a lot of research into it yet. |
mb911 |
Mar 26 2020, 08:07 PM
So my question is If i have the factory 914-6 oil line off the case but plan on running the front mount cooler with the thermostat is the oil line i have not needed. I never have been able to find a diagram of what this system would look like finished, admittedly I never did put a lot of research into it yet. No the factory scavenge line is not needed.. You would need the GT hardlines and the factory would have used a 911rsr /S. T stat setup and this is a much cheaper solution then that.. |
Lo-Fi Version | Time is now: 2nd May 2024 - 04:07 AM |
