Engine tear down, Engine help |
simonjb |
Mar 26 2020, 07:00 PM
KiwiMan Group: Members Posts: 563 Joined: 18-October 16 From: Stamford, Connecticut Member No.: 20,505 Region Association: North East States |
So I decided to clean up my original engine while I run the car with a modified scat engine.
When I drained the oil I found these....two small pieces and the nut.....(dime for size). So I started to tear down the top end and found one cylinder that looked not so good. The others are the same as the right side. went down further and removed the pistons and am now cleaning them all up. Everything looks ok. I really don’t want to split the case or go any further and from what I see inside all look good. So two questions.... 1) any thought on why this cylinder isn’t firing right ? 2) can I use something like gasoline or similar to flush and clean out the inside of the case with the crank and oil pump etc still attached? 3) any reason why I can’t use all the old parts ? 4) any thought on the nut? Thanks.... |
Tbrown4x4 |
Mar 26 2020, 07:28 PM
Senior Member Group: Members Posts: 704 Joined: 13-May 14 From: Port Orchard, WA Member No.: 17,338 Region Association: None |
Why did you pull the engine? How long did it sit?
That's a lot of rust to just put everything back together without a trip to the machine shop. The nut kind of looks like a rod nut, but can you get a boroscope into the case and see if any are missing? In my eyes, that should be a full tear down and inspection. |
Lo-Fi Version | Time is now: 19th May 2024 - 10:05 AM |
