Engine tear down, Engine help |
simonjb |
Mar 26 2020, 07:00 PM
KiwiMan Group: Members Posts: 563 Joined: 18-October 16 From: Stamford, Connecticut Member No.: 20,505 Region Association: North East States |
So I decided to clean up my original engine while I run the car with a modified scat engine.
When I drained the oil I found these....two small pieces and the nut.....(dime for size). So I started to tear down the top end and found one cylinder that looked not so good. The others are the same as the right side. went down further and removed the pistons and am now cleaning them all up. Everything looks ok. I really don’t want to split the case or go any further and from what I see inside all look good. So two questions.... 1) any thought on why this cylinder isn’t firing right ? 2) can I use something like gasoline or similar to flush and clean out the inside of the case with the crank and oil pump etc still attached? 3) any reason why I can’t use all the old parts ? 4) any thought on the nut? Thanks.... |
porschetub |
Mar 26 2020, 08:54 PM
Advanced Member Group: Members Posts: 4,701 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None |
Water has entered the motor so you need a top overhaul,the heads will need work also,I flushed out my last crankcase with petrol and was amazed @ the shit that came out and then did a final wash with brakeclean,came out really clean.
You will have limited use of the existing parts unless you rebore the barrels to 96mm with new pistons,unless you can find a good used 94mm barrel and piston for that cylinder you have had water in. The heads will need rebuilding if they aren't cracked or have bad seats and guides other than that a good used set may be a better option...depends on your funds. That isn't a rod nut ,appears to be a random someone dropped in there,in the early days I found part of a spring in my 911 conversion motor and none of the wise men on Pelican knew what it was so wasn't worried. |
Lo-Fi Version | Time is now: 19th May 2024 - 10:09 AM |
