harness bar, looking to mount harnesses |
garm |
Mar 27 2020, 08:42 AM
Newbie Group: Members Posts: 21 Joined: 23-June 18 From: Chatsworth CA Member No.: 22,247 Region Association: Southern California |
Hi guys, I'm sure this is well covered but some searches didn't help me.
I have racing seats installed (Cobra) and I want to install harnesses now. I was looking for a harness bar; there are pictures on the internet (Weltmeister, for example) but I could not find a way to buy one. The other option I've seen is footman loops or eyebolts through the firewall. Is it the consensus that is a safe mounting point? I'm not a hardcore racer, just autocross or occasional weekend track day, and canyon/driving runs. I don't really want to do a custom, welded solution at this time. Thoughts? Links? Thanks guys. |
infraredcalvin |
Mar 30 2020, 07:41 PM
Distracted Member Group: Members Posts: 1,504 Joined: 25-August 08 From: Ladera Ranch, CA Member No.: 9,463 Region Association: Southern California |
If you go through the firewall you have to remove or drill holes into the back pad. Your best bet is a harness bar that attaches to the seat belt bolts. They pop up for sale from time to time. I’d start with a WTB.
Mar 30 2020, 07:46 PM
914-6 GT in waiting Group: Members Posts: 19,222 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
You have to back up the eyebolts with extra metal.
stownsen914 |
Mar 31 2020, 06:42 AM
Senior Member Group: Members Posts: 912 Joined: 3-October 06 From: Ossining, NY Member No.: 6,985 Region Association: None |
Do you have rollover protection (rollbar or cage) in the car? There has been increasing discussion in recent years whether it makes sense to put in harnesses to hold you firmly upright in the unfortunate circumstance of a rollover. Especially in an open top or targa car like a 914.
jd74914 |
Mar 31 2020, 07:14 AM
Its alive Group: Members Posts: 4,776 Joined: 16-February 04 From: CT Member No.: 1,659 Region Association: North East States |
Also, if you're going to put it in please use DOT-rated harnesses. I'd personally recommend Schroth but there are other brands too. |
DMAYHALL |
Apr 8 2020, 03:56 PM
Newbie Group: Members Posts: 13 Joined: 26-June 14 From: las vegas Member No.: 17,557 Region Association: None |
I am in early stages of making these. PM me and we can build you one.
GregAmy |
Apr 9 2020, 06:36 AM
Advanced Member Group: Members Posts: 2,264 Joined: 22-February 13 From: Middletown CT Member No.: 15,565 Region Association: North East States |
The biggest concerns with harness bars are spinal compression fractures. If you have a an over-the-shoulder strap that goes "downward" behind the seat, and you do not have a lap belt that firmly keeps your butt down in the seat, then the harness can compress your shoulders, and thus your spine, in case of a rollover.
This is why in racing we do not allow the over-the-shoulder harnesses in a 5- or 6-point to angle down more than 20 degrees from horizontal, and lap belts shall be firmly snugged. |
ChrisFoley |
Apr 10 2020, 05:00 AM
I am Tangerine Racing Group: Members Posts: 7,907 Joined: 29-January 03 From: Bolton, CT Member No.: 209 Region Association: None |
In a 914, the shoulder belt attachment points are far too high for a useful harness bar. I'm not a fan. If anyone wants to keep the stock interior without altering the upholstery, just use the stock belts.
Otherwise, the GT shoulder harness bolts are a good choice for a car that has no roll cage harness crossbar. I once made a custom harness bar that mounted closer to the proper height by using the air vent oval holes to mount end brackets securely. |
Lo-Fi Version | Time is now: 19th April 2024 - 02:09 PM |
