Rear Rotor Removal, rusted stuck? Not Anymore!, Two Screws? |
cassmcentee |
Mar 27 2020, 02:00 PM
Member Group: Members Posts: 180 Joined: 12-July 18 From: Squaw Valley, CA Member No.: 22,304 Region Association: Central California |
Is the rear rotor held on to the hub by these two screws at this point?
I have Soaked/Heated/Hammered but the screws aren't budging. Am I missing something here??? My guess is they are rusted in place... I have a torch with a rosebud tip, didn't heat the rotor to red thinking that I could possibly warp the rotor...so I just went close to red... Do I have to drill these and then tap them out? Thank You, Cass |
porschetub |
Mar 27 2020, 02:19 PM
Put a punch which is about the same size as the recessed hole and hit very hard with a hammer,then use an impact wrench the fits the slot properly,if this fails center punch (dead centre) the screws and drill them till the heads are gone.
Once the disk is off the remains of the screws should wind out with ease,good luck. |
Mar 27 2020, 02:25 PM
914-6 GT in waiting Group: Members Posts: 19,254 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
MAP torch is your friend.
kroelofsen |
Mar 27 2020, 02:45 PM
Member Group: Members Posts: 100 Joined: 27-June 19 From: The Netherlands Member No.: 23,255 Region Association: Europe |
Drill them out...
Bmw635 |
Mar 27 2020, 02:47 PM
Member Group: Members Posts: 66 Joined: 19-February 20 From: OC, CA Member No.: 23,943 Region Association: Southern California |
Could try this impact driver. Hammer the handle and the bit will twist in direction you want while pushing the tip in to prevent rounding.
cassmcentee |
Mar 27 2020, 03:05 PM
Okay, Great!
So they are the criminals holding tight then. I have hammered and given a couple of attacks with my impact Will soak tonight, heat/hammer/impact in the morning again... Drill out if all else fails. Thank ya'll |
jsaum |
Mar 27 2020, 07:00 PM
Senior Member Group: Members Posts: 530 Joined: 12-June 07 From: Everett, WA Member No.: 7,809 Region Association: None |
I’ve had good luck using PB blaster. Let it soak for a few days then use heat. MAP gas gets hotter than standard propane, I’ve heated then spayed to cycle from hot to cool. Get the metal expanding and contracting to break the rust loose.
GaroldShaffer |
Mar 27 2020, 07:24 PM
You bought another 914? Group: Benefactors Posts: 7,620 Joined: 27-June 03 From: Portage, IN Member No.: 865 Region Association: None |
Drill the heads off then pull the rotor off. Once that is off use a vise grip to clamp on the remaining threaded stud and slowly twist out. You still may need to heat it, but you won't hurt the hub. I agree with using a MAP torch to heat with.
914forme |
Mar 27 2020, 07:33 PM
(IMG:style_emoticons/default/agree.gif) And if the rotor is stuck, big puller will work, put two lug bolts, so the rotor and puller don't go shooting across the garage.
IronHillRestorations |
Mar 27 2020, 07:41 PM
I. I. R. C. Group: Members Posts: 6,716 Joined: 18-March 03 From: West TN Member No.: 439 Region Association: None |
I'd probably keep soaking it with Seafoam Deep Creep or 1 part ATF with 1 part acetone, those are the best penetrating fluids I've found. I'd also take a screwdriver and hammer and tap straight in on the screws, like you're driving it in, several times a day. It might take a couple days but the fluid will work it's way in. If you don't want to wait then take Garold's advice and drill off the heads of the screws.
The rotors have two threaded holes for screwing an M6 bolt in to pop them off the hub. |
914forme |
Mar 27 2020, 07:46 PM
Thanks Perry, learned something new today.
Mar 27 2020, 08:00 PM
The guys at the shop use a MAP torch because they want to get it done in minutes instead of waiting days for penetrating fluid. It's a very useful tool for working on old cars.
The trick one of the guys taught me is to touch the cooling metal with a piece of paraffin. The wax will wick into the threads and make it easier to loosen while penetrating fluid will just evaporate. |
Amphicar770 |
Mar 27 2020, 08:14 PM
Senior Member Group: Members Posts: 1,188 Joined: 20-April 10 From: PA, USA Member No.: 11,639 Region Association: MidAtlantic Region |
Try one of these
https://youtu.be/Pwz-NXj5ZIk Google aircraft screw extractor and you will find similar. |
Spoke |
Mar 27 2020, 08:20 PM
I had the same problem with my 914. I drilled the heads off but the rotors were rusted to the hubs. Had to pound the rotors off with a hammer. I was replacing the rotors so didn't matter if they were beat up.
bkrantz |
Mar 27 2020, 08:38 PM
914 Guru Group: Members Posts: 7,742 Joined: 3-August 19 From: SW Colorado Member No.: 23,343 Region Association: Rocky Mountains |
914werke |
Mar 27 2020, 09:34 PM
"I got blisters on me fingers" Group: Members Posts: 10,037 Joined: 22-March 03 From: USofA Member No.: 453 Region Association: Pacific Northwest |
Motorcyclists are probably very familiar (IMG:style_emoticons/default/smile.gif) Ive wore out a couple of these |
bdstone914 |
Mar 27 2020, 10:12 PM
bdstone914 Group: Members Posts: 4,515 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
@cassmcentee
After you get the screws out you may find the rotor stuck to the hub. There are two threaded holes that take an 8mm bolt. Screw in two bolts sequentially tightening. Most all rotors that fit over hubs have them. Attached thumbnail(s) |
Porschef |
Mar 28 2020, 06:07 AM
How you doin' Group: Members Posts: 2,165 Joined: 7-September 10 From: LawnGuyland Member No.: 12,152 Region Association: North East States |
Could try this impact driver. Hammer the handle and the bit will twist in direction you want while pushing the tip in to prevent rounding. This is my favorite and always successful tool, that I keep around just for that job. (IMG:style_emoticons/default/agree.gif) Last time I used this was for exactly the same purpose. Clean the slot thoroughly, make sure the tip fits properly. Heat, spray in some PB Blaster, Liquid Wrench, or penetrant of your choice, (yes, the ATF/acetone works well, been using it for years, but you need to shake frequently to keep it mixed), repeat, seat the impact square and whack it but good with a lumpy hammer. It’ll come off, and provide you with a sense of accomplishment... (IMG:style_emoticons/default/beerchug.gif) |
cassmcentee |
Mar 28 2020, 07:53 AM
Thanks Ya'll!
I wondered what those other two holes were for Makes perfect sense P.S. I've been using my acetylene torch with a rosebud tip. Had to heat the axle nut to RED just to get it off. This car sat on the ground for way too many years. |
Jamie |
Mar 28 2020, 09:09 AM
Senior Member Group: Members Posts: 1,025 Joined: 13-October 04 From: Georgetown,KY Member No.: 2,939 Region Association: South East States |
[quote name='Bmw635' date='Mar 27 2020, 12:47 PM' post='2798273']
Could try this impact driver. Hammer the handle and the bit will twist in direction you want while pushing the tip in to prevent rounding. [/quote Don't overlook the fact that these impact drivers have Forward and Reverse settings. (IMG:style_emoticons/default/sunglasses.gif) |
Lo-Fi Version | Time is now: 3rd May 2024 - 04:01 PM |
