Video for installing rubber trailing arm bushings?, Thought Cuddy made one, cannot find it. |
Mueller |
Mar 27 2020, 02:56 PM
Decided to ditch the hard plastic bushings and go with the rubber versions from 914 Rubber.
There are instructions for the A-arms (and I found Cuddy K's video) however for the trailing arms I see no such thing. Thanks, Mike |
iankarr |
Mar 27 2020, 04:54 PM
The wrencher formerly known as Cuddy_K Group: Members Posts: 2,473 Joined: 22-May 15 From: Heber City, UT Member No.: 18,749 Region Association: Intermountain Region |
Hey Mike,
I'll be doing a trailing arm video once I get the bumblebee back from paint. I wish I could help, but I haven't actually done a trailing arm bushing yet. So working on the bumblebee should be fun (IMG:style_emoticons/default/wink.gif). I'm sure the fellas at 914Rubber and the brain trust here can help in the meantime. Thanks for watching the videos! |
Mikey914 |
Mar 27 2020, 05:04 PM
The rubber man Group: Members Posts: 12,661 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
No video but @tvdinnerbythepool did post up a pic or two months the GB thread
http://www.914world.com/bbs2/index.php?sho...=341753&hl= |
76-914 |
Mar 27 2020, 05:45 PM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,500 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
Mike, IIRC Elephant site has it. I laugh every time I see those carpenters C clamps that they use. I wish they were so easy to pull. I use a 12 ton press and even it grunts sometimes.
Mueller |
Mar 27 2020, 07:10 PM
I got them in, couldn't find the Elephant video so I just took a stab at them. No biggie with a HF press and an assortment of large washers and scrap pieces laying around.
Thanks. Mike |
tvdinnerbythepool |
Mar 27 2020, 07:14 PM
Member Group: Members Posts: 310 Joined: 24-July 18 From: Olympia, WA Member No.: 22,336 Region Association: Pacific Northwest |
Mueller |
Mar 27 2020, 07:20 PM
Excuse the mess. Hardest part is holding the arms level.
Yes, that is a Boxster rear hub I installed a few hours ago. |
Mueller |
Mar 27 2020, 07:22 PM
Excuse the mess. Hardest part is holding the arms level. Yes, that is a Boxster rear hub I installed a few hours ago. I may have squeezed the rubber too much, hopefully it has some memory and springs back some. Same amount of axle sitting proud of rubber on both sides. |
bkrantz |
Mar 27 2020, 08:56 PM
914 Guru Group: Members Posts: 7,761 Joined: 3-August 19 From: SW Colorado Member No.: 23,343 Region Association: Rocky Mountains |
Mueller |
Mar 28 2020, 09:17 AM
I left the OD dry , freshly powder coated trailing arms so they had a nice smooth surface.
76-914 |
Mar 28 2020, 09:26 AM
That stand holding the arm is the key. Otherwise you'll need a 3rd hand. I hated those noises plastic bushings. Did you use Elephants or 914 Rubber's bushings. I was curious if the 914 Rubber bushings fit as tightly?
Mueller |
Mar 28 2020, 01:53 PM
That stand holding the arm is the key. Otherwise you'll need a 3rd hand. I hated those noises plastic bushings. Did you use Elephants or 914 Rubber's bushings. I was curious if the 914 Rubber bushings fit as tightly? I used the 914Rubber rubber bushings. They took some effort to slide into the arms by themselves, not too bad. My order of installation. Push bushing into "short" side of arm tube with arm laying flat on side facing trunk wall, "tall" side of arm facing upwards. Then I pushed the axle into already installed bushing from the top side. Now place bushing in arm. This side gave me more trouble or resistance. See newly drawn pics for a rough idea how it was done. |
Lo-Fi Version | Time is now: 14th May 2024 - 04:39 AM |
