Upright cooling. Whose system have you used? |
B2524 |
Mar 28 2020, 09:44 AM
It's a sickness. Group: Members Posts: 72 Joined: 12-November 11 From: Outside Paso Robles CA Member No.: 13,776 Region Association: Northern California |
Looking for an upright cooling system for a big motor. Not interested in one that needs the case to be machined. My engine is built.
Anyone use s CSP? How about one that used the 911 styyfan? Thanks for info. |
Mark Henry |
Mar 28 2020, 11:14 AM
I have one in my bug that I made, sort of a stock T1/Joe Cali/ DTM hybrid metal shroud.
I've installed severial DTM's, a couple of Sharpbuilt, FAT... I haven't done one in a 914. Why do you need one? |
Mark Henry |
Mar 28 2020, 11:20 AM
My '67 bug, T4 conversion, I made the shroud, 2600cc, 102mm nickies, JE's, SDS EFI, 46mm TB's, etc coupled to a 901 (911) transmission with stock 914/4 gearing.
(IMG:http://www.914world.com/bbs2/uploads/post-26-1403266589.jpg) |
B2524 |
Mar 28 2020, 01:08 PM
Got a big engine and going to see track use.
Anyone with a 911 style fan out there? |
Mark Henry |
Mar 28 2020, 02:04 PM
Got a big engine and going to see track use. Anyone with a 911 style fan out there? It's been talked to death, on a type 4 a 911 fan isn't as efficient as a T4 fan, it moves too much air which I know sounds odd, but it also doesn't do it evenly. My choice would be stock cooling or: - 914 DTM, external oil cooler required. Uses stock Type 1 alternator and fan. https://lnengineering.com/type-4-store/dtm-...ic-dtm-kit.html -Tangerine racing has an horizontal fan kit. http://www.tangerineracing.com/engine.htm Con for both systems is if the fan belt goes you lose your cooling. |
Tdskip |
Mar 28 2020, 07:27 PM
Advanced Member Group: Members Posts: 3,686 Joined: 1-December 17 From: soCal Member No.: 21,666 Region Association: None |
It's been talked to death, on a type 4 a 911 fan isn't as efficient as a T4 fan, it moves too much air which I know sounds odd, but it also doesn't do it evenly. My choice would be stock cooling or: - 914 DTM, external oil cooler required. Uses stock Type 1 alternator and fan. https://lnengineering.com/type-4-store/dtm-...ic-dtm-kit.html -Tangerine racing has an horizontal fan kit. http://www.tangerineracing.com/engine.htm Con for both systems is if the fan belt goes you lose your cooling. How far do you think stock cooling can get you if you also run an oil cooler? |
Mark Henry |
Mar 29 2020, 07:50 AM
It's been talked to death, on a type 4 a 911 fan isn't as efficient as a T4 fan, it moves too much air which I know sounds odd, but it also doesn't do it evenly. My choice would be stock cooling or: - 914 DTM, external oil cooler required. Uses stock Type 1 alternator and fan. https://lnengineering.com/type-4-store/dtm-...ic-dtm-kit.html -Tangerine racing has an horizontal fan kit. http://www.tangerineracing.com/engine.htm Con for both systems is if the fan belt goes you lose your cooling. How far do you think stock cooling can get you if you also run an oil cooler? 100K miles (IMG:style_emoticons/default/confused24.gif) but not all at once.... |
Tdskip |
Mar 29 2020, 08:06 AM
That made me almost snort my coffee - good morning to you. What I am really asking is life expectancy on a build like this - I’ve heard 30-40k before it comes apart again and am wondering how much / if any this sort of upright cooling extends that (which I think aligns to the OP question). Impossible to state exactly obviously, wonder if there is any ballpark learned experience. Thanks! |
GregAmy |
Mar 29 2020, 08:48 AM
Advanced Member Group: Members Posts: 2,289 Joined: 22-February 13 From: Middletown CT Member No.: 15,565 Region Association: North East States |
A +1 on the Tangerine system, if you're going that way. I have one of Chris' Prod engines with that cooling system in my vintage racer and it's pretty cool (har-de-har). Not cheap, but if I was going that direction that's the avenue I'd take.
Mark Henry |
Mar 29 2020, 09:02 AM
That made me almost snort my coffee - good morning to you. What I am really asking is life expectancy on a build like this - I’ve heard 30-40k before it comes apart again and am wondering how much / if any this sort of upright cooling extends that (which I think aligns to the OP question). Impossible to state exactly obviously, wonder if there is any ballpark learned experience. Thanks! Depends (IMG:style_emoticons/default/biggrin.gif) Only gentlemen racers are going to get 30-40K. Many guys tear down and refresh the engine yearly or every few years. More serious racers (AKA have the cash) will have a backup engine and may refresh the engine(s) throughout the season. The big thing is the quality of the build and is it well sorted. Not a cheap game, even with all the best kit shit happens. |
stownsen914 |
Mar 30 2020, 10:54 AM
Senior Member Group: Members Posts: 913 Joined: 3-October 06 From: Ossining, NY Member No.: 6,985 Region Association: None |
One of the best things you can do on a tracked aircooled motor is monitor your temps carefully. I am conservative on the oil temps and prefer not much over 200 degrees personally. This usually means a substantial front mounted cooler for a tracked car.
You can also monitor cyl head temps, especially if you are concerned about them. My experience is more with 911 motors, but I've understood this is a challenged area for the type 4s. On a 911 you like to see 200-250 cyl head temp. I'm not sure for type 4's. I'm sure someone here will know. |
Lo-Fi Version | Time is now: 7th May 2024 - 06:46 PM |
