Factory 914-6 engine mount clearance issue?, When used on a 3.2 or 3.6 |
Luke M |
Mar 29 2020, 06:50 AM
Senior Member Group: Members Posts: 1,368 Joined: 8-February 05 From: WNY Member No.: 3,574 Region Association: North East States |
Thinking of getting a 3.2 or a 993 3.6. If using the factory 914-6 engine mount will I run into any clearance issues around the crank pulley area?
I know of a few other issues that I may encounter. For you 3.2 and 3.6 guys out there any words of wisdom before I jump into this? |
rgalla9146 |
Mar 29 2020, 07:14 AM
Advanced Member Group: Members Posts: 4,544 Joined: 23-November 05 From: Paramus NJ Member No.: 5,176 Region Association: None |
Never done it but understand pully has to be changed which elimenates
accessory drive ? |
Luke M |
Mar 29 2020, 07:25 AM
Never done it but understand pully has to be changed which elimenates accessory drive ? Hi Rory, I just do not want to have to cut up a nice factory 6 mount. I have several different crank pulleys here that I could try out if need be. That would also change the fan ratio/speed too. I'll send you a pm later on the other stuff we talked about. Thanks, |
Mark Henry |
Mar 29 2020, 08:01 AM
Never done it but understand pully has to be changed which elimenates accessory drive ? AC pulley won't work without major mods, find a single pulley with the same fan drive size. IIRC any air cooled pulley will work but there's a few different sizes of the crank pulley and then there's a couple different sizes of the fan pulleys. Do a search on pelican, there was a list of the different sizes. I went with the SC sized pulleys on the right , I can just sneak the belt past the tin, would be a PITA to change the belt in car without my big access hole. (IMG:http://www.914world.com/bbs2/uploads/post-26-1391692879.jpg) |
Mar 29 2020, 08:25 AM
914-6 GT in waiting Group: Members Posts: 19,222 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
Can't you just put the double pulley on a lathe and knock off the smaller one?
mb911 |
Mar 29 2020, 08:30 AM
914 Guru Group: Members Posts: 6,801 Joined: 2-January 09 From: Burlington wi Member No.: 9,892 Region Association: Upper MidWest |
IronHillRestorations |
Mar 29 2020, 08:48 AM
Pretty sure the lower pulley on a 3.6 is also harmonic balancer
Steve |
Mar 29 2020, 09:20 AM
914 Guru Group: Members Posts: 5,565 Joined: 14-June 03 From: Orange County, CA Member No.: 822 Region Association: Southern California |
I took the single pulley off of my 2.7 and put it on my 3.2. I still have the double pulley off of the 3.2 in a box somewhere. I am using the rich Johnson Mount.
bahnzai |
Mar 29 2020, 10:50 AM
Member Group: Members Posts: 305 Joined: 26-July 06 From: Columbia, SC Member No.: 6,509 Region Association: South East States |
mb911 |
Mar 29 2020, 10:58 AM
Here is a 3.6 with a stock mount unmodified. As others noted, only room for single belt. My conversion already had the stock mount installed. If I were starting from scratch, I would use the style Bob Saville or Patrick Motorsports offers. Looks much easier/quicker to drop the motor. The problem with those above mentioned mounts is that it mounts the engine about 3/4" lower in the chassis thus making the seals not able to meet up.. Then you also can't use a stock style oil line set up. |
Mark Henry |
Mar 29 2020, 11:18 AM
The problem with those above mentioned mounts is that it mounts the engine about 3/4" lower in the chassis thus making the seals not able to meet up.. Then you also can't use a stock style oil line set up. I have my nose dropped close to 3/4" and I think my seals fit better. I have be sure to hook them over the tin edge when I install, but they stay perfectly in place. I can't use the stock oil pipe as I made my own mount which is much like a RJ mount. |
Luke M |
Mar 29 2020, 11:23 AM
I currently have a 131 mm crank pulley and stock 6 upper.
With the 131 mm installed it's tight to swap out the belt. I don't think I would be able to get one on if needed. Maybe with the fan access hole cut into the firewall. Yeah I know some would say bad idea.. I also have a 3.2, 2 belt and single pulley here. I'll have to find them so I can test it out. I believe the 3.6 engine mount is a totally different style mount ? I'm also gonna stay with the factory 6 mount not an aftermarket unit. Attached image(s) |
JOEPROPER |
Mar 29 2020, 12:01 PM
The answer is "no" unless you ask... Group: Members Posts: 1,184 Joined: 21-November 15 From: White Plains New York Member No.: 19,387 Region Association: North East States |
Here is a 3.6 with a stock mount unmodified. As others noted, only room for single belt. My conversion already had the stock mount installed. If I were starting from scratch, I would use the style Bob Saville or Patrick Motorsports offers. Looks much easier/quicker to drop the motor. The problem with those above mentioned mounts is that it mounts the engine about 3/4" lower in the chassis thus making the seals not able to meet up.. Then you also can't use a stock style oil line set up. Sorry to go backwards, but which above mentioned mounts are you referring to Ben? PMS / NARO RACING? or RJ or factory 6? Also excuse my ignorance... thanks. |
mb911 |
Mar 29 2020, 12:24 PM
Sorry naroscape and pms..
rgalla9146 |
Mar 29 2020, 01:40 PM
I agree with Mark that the second groove can be machined off the original pulley.
Also,there should be a known correct distance from the engine shelf down to crank centerline. In my experience mechanics either don't bother to engage the seals to the engine tin or it tends to get loose on its own. It's an important barrier. |
gms |
Mar 30 2020, 09:05 AM
Advanced Member Group: Members Posts: 2,694 Joined: 12-March 04 From: Chicagoland Member No.: 1,785 Region Association: Upper MidWest |
Luke M |
Mar 30 2020, 02:22 PM
I'm waiting to hear back about a 993 3.6. If it doesn't work out I'll go with a 3.2.
Any one have a late 84-86 915 trans converted with Bott's 916 kit all done that they may want to part with? |
Mar 30 2020, 02:35 PM
I'm waiting to hear back about a 993 3.6. If it doesn't work out I'll go with a 3.2. Any one have a late 84-86 915 trans converted with Bott's 916 kit all done that they may want to part with? Didn’t LarryM have the trans and kit for sale some time ago. Found it - http://www.914world.com/bbs2/index.php?sho...2&hl=Martin |
Steve |
Mar 30 2020, 04:33 PM
Maybe also check with http://www.tangerineracing.com/
They build quite a few of them and had one for sale awhile back |
RiqueMar |
Apr 6 2020, 09:32 PM
Enrique Allen Mar Group: Members Posts: 2,169 Joined: 28-August 08 From: San Diego, CA Member No.: 9,478 Region Association: Southern California |
Should you change your mind, and decide to use the actual /6 mount, I went that route, and only had to slightly modify the cone.
http://www.914world.com/bbs2/index.php?sho...8955&st=680 Hope this helps and best of luck! |
Lo-Fi Version | Time is now: 19th April 2024 - 03:38 PM |
