Springs, Shocks and Pegs, (well perhaps no Pegs) |
ctc911ctc |
Mar 30 2020, 07:57 PM
Senior Member Group: Members Posts: 890 Joined: 9-June 18 From: boston Member No.: 22,206 Region Association: North East States |
OK,
I am a bit envious. Seems that many of you have figured out how to purchase springs and shocks for the rear of the 914. I have found myself going to different web sites being completely confused and as a result looking at all of you with envy. Shocks, Pegs......Lucky! The 914 rubber guys have 150lb springs, no shocks. Various sites have Bilstein's and then a few have an 'adjustable' gas shock called KYB. I found some 'racing' sites with 500lbs springs and then many options - mostly indecipherable. I need some couch time, here is what I am looking for. I have a mostly original '74 2.0 with a blown rear shock - that blown shock is original, which I am sure comes as no shock. The car seems to be a couple of inches lower than stock, I would like to have it ride a bit higher Other than that, original safe performance is all that I am seeking - What would you recommend? Spring LBS capability? Vendor? Approximate costs for estimates? Thank you! |
porschetub |
Mar 30 2020, 08:30 PM
I don't know the stock spring rates but the PO told me my Bilsteins have 100 pound springs and IMO they work with the extra weight of the "6".
Bruce Stone has some good used ones in the FS/WTB section ,he only sells good stuff so would pay to contact him ASAP as they will sell fast @ his pricing. |
914_teener |
Mar 30 2020, 09:19 PM
914 Guru Group: Members Posts: 5,194 Joined: 31-August 08 From: So. Cal Member No.: 9,489 Region Association: Southern California |
140.....Spring Rate Bilstein Sports with adjustable perches.
Rebel Racing. $800....rear auspension only. Rim width and tires will also dictate the handling of the car. They figure into the equation. Plenty of threads here.....search is your best friend for the couch. |
bdstone914 |
Mar 30 2020, 09:34 PM
bdstone914 Group: Members Posts: 4,512 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
OK, I am a bit envious. Seems that many of you have figured out how to purchase springs and shocks for the rear of the 914. I have found myself going to different web sites being completely confused and as a result looking at all of you with envy. Shocks, Pegs......Lucky! The 914 rubber guys have 150lb springs, no shocks. Various sites have Bilstein's and then a few have an 'adjustable' gas shock called KYB. I found some 'racing' sites with 500lbs springs and then many options - mostly indecipherable. I need some couch time, here is what I am looking for. I have a mostly original '74 2.0 with a blown rear shock - that blown shock is original, which I am sure comes as no shock. The car seems to be a couple of inches lower than stock, I would like to have it ride a bit higher Other than that, original safe performance is all that I am seeking - What would you recommend? Spring LBS capability? Vendor? Approximate costs for estimates? Thank you! Stock springs are 55lb. 100 lb to replace them is a good start. I have a bunch of good used shocks that were tested by Eibach when I was working with 914 Rubber to developed the springs they have. The stock shocks can not change the rear ride height. If you want to change that you need a Koni or Bilstein with an adjustable perch. If it is low in the back the springs are probably saging. Bruce 914World.com | FS Used and Sachs- BOGE Rear assemblies http://www.914world.com/bbs2/index.php?showtopic=344379 |
ctc911ctc |
Mar 31 2020, 07:04 AM
Have already searched without any good luck, that is why I posted here. If you know of some good threads, could your post them please? Please? 140.....Spring Rate Bilstein Sports with adjustable perches. Rebel Racing. $800....rear auspension only. Rim width and tires will also dictate the handling of the car. They figure into the equation. Plenty of threads here.....search is your best friend for the couch. (IMG:style_emoticons/default/dry.gif) |
Olympic 914 |
Mar 31 2020, 07:57 AM
Group: Members Posts: 1,661 Joined: 7-July 11 From: Pittsburgh PA Member No.: 13,287 Region Association: North East States |
I went with the setup from Ground Control.
https://groundcontrolstore.com/collections/...=19739474395232 Was looking for a good street ride, Not too stiff. So I ordered the 125# springs. Previously was running 914/6 rear springs with KYB shocks. I think they were 100# springs. (Two yellow dots) This setup handles great using the stock front torsion bars. and Bilstein front shocks. But I have not had it on the track. Eventually I may get Konis for the front also, but for now it works just fine. You can see a picture in my build thread at the bottom of my Sig, post #116 |
VaccaRabite |
Mar 31 2020, 10:08 AM
En Garde! Group: Admin Posts: 13,423 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region |
The first time I did it, I bought 140lbs springs and kept my KYBs. That was the cool AX setup at the time, or so my noob resarch showed. My ride height was off - raked higher in the rear. I was never happy with that - and waited about 10 years for my suspension to settle. Yeah, right.
When I recently redid my suspension, I called Eric Shea and bought what I needed from him. Way, WAY better. Zach |
acar24 |
Mar 31 2020, 10:52 AM
Newbie Group: Members Posts: 2 Joined: 3-April 07 From: Ne Member No.: 7,641 Region Association: None |
I have this set that have been in the garage, need cleaned. Have 3 green paint marks
the shocks were good, I'm not sure what they are, Mexican monroes? - bolt on. 150 + shipping? LA Attached thumbnail(s) |
Mikey914 |
Mar 31 2020, 10:58 AM
The rubber man Group: Members Posts: 12,638 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
We are in the process of doing shocks and struts with Eibach, but the Covid thing has shut them down for now.
We will be doing a Group buy on a complete system, but it's a ways off. If you need something not the Bilstiens as the best bang for the buck right now. We have the 100# and a 140/160 progressive spring. Mark BTW The shocks Bruce has would be an easy way to save a few bucks |
ctc911ctc |
Apr 1 2020, 02:30 PM
********Bought Shocks********
**********and springs******** **********and adjusters****** With the various suggestions, I talked with Donovan at Ground Control - will let you know how they turn out and mount, etc. I was very tempted with some of the used ideas, also the cost! However, I want to get something that I can adjust and set the height of the back. Thank you teeners! |
ctc911ctc |
Apr 9 2020, 08:32 AM
Final post of this thread - MAN getting those originals off was a pistol. Lot's of heat for a LONG time!
Big Difference Now I need to clean the underside of the car to match!! Attached image(s) |
TheCabinetmaker |
Apr 9 2020, 09:16 AM
I have 160 progressives with Bilstein sports. Love em!
mlindner |
Apr 9 2020, 09:48 AM
Senior Member Group: Members Posts: 1,511 Joined: 11-November 11 From: Merrimac, WI Member No.: 13,770 Region Association: Upper MidWest |
dr914@autoatlanta.com |
Apr 9 2020, 09:58 AM
914 Guru Group: Members Posts: 7,814 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None |
if you purchase the original duplicate factory springs you cannot go wrong.
there is a set for the 914-6 because of the heavier engine weight there is a set for the 914-4 do not guess on spring rates, do it the way the engineers did it. (unless you are racing your car!!!!) ote name='ctc911ctc' date='Mar 30 2020, 06:57 PM' post='2799294'] OK, I am a bit envious. Seems that many of you have figured out how to purchase springs and shocks for the rear of the 914. I have found myself going to different web sites being completely confused and as a result looking at all of you with envy. Shocks, Pegs......Lucky! The 914 rubber guys have 150lb springs, no shocks. Various sites have Bilstein's and then a few have an 'adjustable' gas shock called KYB. I found some 'racing' sites with 500lbs springs and then many options - mostly indecipherable. I need some couch time, here is what I am looking for. I have a mostly original '74 2.0 with a blown rear shock - that blown shock is original, which I am sure comes as no shock. The car seems to be a couple of inches lower than stock, I would like to have it ride a bit higher Other than that, original safe performance is all that I am seeking - What would you recommend? Spring LBS capability? Vendor? Approximate costs for estimates? Thank you! [/quote] |
ndfrigi |
Apr 9 2020, 10:28 AM
Bought a pair rear shocks last February and it was ship last Feb. 18 in Pompano Beach, FL and it was in LA facility by Feb. 23 and should be delivered on my door Feb. 25. Well after several follow-up from me and the seller, USPS said it is at the Bell Garden facility.
Well never got them and no more update what happen to my shocks. Until now still show on the tracking status the same info that the item is still within the Nerwork faciltiy. Shipping cost $65 for it and it just went MIA (missing in action)! |
IronHillRestorations |
Apr 9 2020, 12:55 PM
FWIW, I'm going through a spring selection process right now. I spent quite a bit of time last night researching 2.25 id springs for the adjustable perches we got from a member here. He included the helper springs and spacer, with 8" 200 and 225 lb springs which are too much for this project.
I wanted to use the last set of 160 progressives I got from ^Dave Shepard^ RIP, but they are (of course) too large diameter and don't have flat ends, and really require stock upper and lower spring perches. I found a place in the UK that has a big selection of 2.25 springs in different lengths. I'm thinking that a longer (than 8") spring with the same load rating will give more suspension travel and provide more adjustability. Burton Power UK They have a 14" 120 lb spring that I think would be worth a try I'm also looking at a 9" Hypercoil in 130 lb These are also a consideration Twisted springs I got a tip years ago about using a spare wheel/tire to push on to compress the springs if you don't have a spring compressor, and it works pretty good with two people |
Lo-Fi Version | Time is now: 24th April 2024 - 03:22 AM |
