adventures in suspension, I took some measurements... |
914 RZ-1 |
Mar 30 2020, 08:16 PM
Porsche Padawan Group: Members Posts: 683 Joined: 17-December 14 From: Santa Clarita, CA Member No.: 18,230 Region Association: Southern California |
I was on a drive with some other folks on Sunday (don't worry; we all kept 6 feet apart) and the guy behind me tells me that when I turn hard right the car leans more than when I turn hard left. Looks like the springs/shocks/suspension needs some attention. Where do I begin?
I have never replaced or adjusted any of the suspension on this car. For replacement parts (if I need them), what are good shocks and springs and where is a good place to get them? I'm not looking for anything fancy; the "stock" ride is fine. Are there any techniques or fancy tools I should know about? Thanks! |
914 RZ-1 |
Apr 4 2020, 04:50 PM
For you kids following along at home, I have more info:
1. I bought rear shocks and springs. Gonna tackle that in a short while. 2. The front Boge/Sachs ones don't seem to be available anymore, just Bilstein. I'll wait until next month to get those to keep the CFO (wife) from freaking out. 3. I did the "bounce test" on all four corners. They all feel a bit soft and are not consistent. 4. I made some measurements: a. I have 205/60 tires b. Front axle height as defined in the Haynes manual (p. 108). Distance from hub cap center to ground is 295.5 mm on driver's side and 299 mm on passenger side. Distance from torsion bar adjuster lever to ground is 135.5 mm (driver)/133 mm (passenger). The difference i supposed to be 90 mm +/- 5 mm. Do the math and you'll get 160.5 mm (driver)/166 mm (passenger). Seems my car has been lowered or the springs are really saggy. c. I also measured from the ground to the bottom of the wheel well as shown in the sketch. The back is pretty consistent (different by 1 mm), but the fronts are different from each other by 25 mm. I didn't think the difference in the front an back dimensions were an issue. In other words, do all 4 dimensions need to be the same? What do I need to do to fix/adjust this? I am thinking I will replace the rear springs and shocks and see what happens. Then replace the front strut inserts and see what effect that has, then go from there. Thoughts? |
Jamie |
Apr 4 2020, 08:50 PM
Senior Member Group: Members Posts: 1,031 Joined: 13-October 04 From: Georgetown,KY Member No.: 2,939 Region Association: South East States |
For you kids following along at home, I have more info: 1. I bought rear shocks and springs. Gonna tackle that in a short while. 2. The front Boge/Sachs ones don't seem to be available anymore, just Bilstein. I'll wait until next month to get those to keep the CFO (wife) from freaking out. 3. I did the "bounce test" on all four corners. They all feel a bit soft and are not consistent. 4. I made some measurements: a. I have 205/60 tires b. Front axle height as defined in the Haynes manual (p. 108). Distance from hub cap center to ground is 295.5 mm on driver's side and 299 mm on passenger side. Distance from torsion bar adjuster lever to ground is 135.5 mm (driver)/133 mm (passenger). The difference i supposed to be 90 mm +/- 5 mm. Do the math and you'll get 160.5 mm (driver)/166 mm (passenger). Seems my car has been lowered or the springs are really saggy. c. I also measured from the ground to the bottom of the wheel well as shown in the sketch. The back is pretty consistent (different by 1 mm), but the fronts are different from each other by 25 mm. I didn't think the difference in the front an back dimensions were an issue. In other words, do all 4 dimensions need to be the same? What do I need to do to fix/adjust this? I am thinking I will replace the rear springs and shocks and see what happens. Then replace the front strut inserts and see what effect that has, then go from there. Thoughts? Original saggy rear springs almost always need #100 replacements, and variation in front may be due to different torsion bar adjustments. |
bkrantz |
Apr 4 2020, 09:06 PM
914 Guru Group: Members Posts: 7,761 Joined: 3-August 19 From: SW Colorado Member No.: 23,343 Region Association: Rocky Mountains |
914 RZ-1 |
Apr 5 2020, 12:48 PM
Original saggy rear springs almost always need #100 replacements, and variation in front may be due to different torsion bar adjustments. Or to opening geometry if a fender has ever been repaired or replaced. The left front fender was replaced by a PO. The car rides fine; no "crabbing", no pulling to one side or uneven tire wear. It appears to have been professionally replaced and done well. |
Lo-Fi Version | Time is now: 14th May 2024 - 12:51 PM |
