adventures in suspension, I took some measurements... |
914 RZ-1 |
Mar 30 2020, 08:16 PM
Porsche Padawan Group: Members Posts: 683 Joined: 17-December 14 From: Santa Clarita, CA Member No.: 18,230 Region Association: Southern California |
I was on a drive with some other folks on Sunday (don't worry; we all kept 6 feet apart) and the guy behind me tells me that when I turn hard right the car leans more than when I turn hard left. Looks like the springs/shocks/suspension needs some attention. Where do I begin?
I have never replaced or adjusted any of the suspension on this car. For replacement parts (if I need them), what are good shocks and springs and where is a good place to get them? I'm not looking for anything fancy; the "stock" ride is fine. Are there any techniques or fancy tools I should know about? Thanks! |
914 RZ-1 |
Apr 5 2020, 10:55 PM
I replaced the original back springs with 100 lb ones from Pelican and Koni shocks with Bilsteins. The car rides about 58 mm higher in back now. No test drive yet; it's late and supposed to rain.
mepstein |
Apr 6 2020, 07:29 AM
914-6 GT in waiting Group: Members Posts: 19,269 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
I replaced the original back springs with 100 lb ones from Pelican and Koni shocks with Bilsteins. The car rides about 58 mm higher in back now. No test drive yet; it's late and supposed to rain. You do need to drive it a bit before checking height. The front insert is even easier to replace than the back. Don't remove the struts, just remove the top nut with a rattle gun and drop them down enough get under the fender lip. Have a pipe wrench handy to remove the threaded cap on the strut. Use a jack under the a arm to get the strut in the correct position once the insert is replaced. |
Lo-Fi Version | Time is now: 13th May 2024 - 11:16 PM |
