1971 Porsche 914 1.7 liter, exhaust |
milwlandrover |
Mar 31 2020, 10:42 AM
Member Group: Members Posts: 149 Joined: 22-June 12 From: Greendale Wisconsin Member No.: 14,592 Region Association: Upper MidWest |
Good morning guys,
I am trying to get some work done while off for this virus deal. I found my right side exhaust studs broke off in the manifold. I had them drilled and heliocoiled and now I need some parts to put it back to gether. I will need 2 exhaust gaskets, 4 studs, 4 nuts and a valve cover gasket. I also found a number of oil leaks and will need 4 push rod tubes and 8 O-rings. where would be the best place and the fastest place to get these from. I have the car on a hoist and don't want to tie it up too long. thanks for your help. ps I have already copied Chris at Tangerine Racing, but I am listing here just in case he doesn't have the parts. cheers! markw |
914Sixer |
Mar 31 2020, 11:07 AM
914 Guru Group: Members Posts: 8,845 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
Mark,
Try Autohausaz.com. |
milwlandrover |
Mar 31 2020, 11:09 AM
milwlandrover |
Apr 1 2020, 07:13 AM
I found everything at Autohauaz.com thank you very much EXCEPT the studs and nuts for the Exhaust manifold. Can anyone help. This project is on someone else's hoist and I don't want to take advantage of his generosity.
thanks |
914sgofast2 |
Apr 1 2020, 10:39 AM
Senior Member Group: Members Posts: 606 Joined: 10-May 13 From: El Dorado Hills, CA Member No.: 15,855 Region Association: None |
I found everything at Autohauaz.com thank you very much EXCEPT the studs and nuts for the Exhaust manifold. Can anyone help. This project is on someone else's hoist and I don't want to take advantage of his generosity. thanks Try PelicanParts.com and FCPEuro.com |
bdstone914 |
Apr 1 2020, 01:13 PM
bdstone914 Group: Members Posts: 4,496 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
@milwlandrover
Mc Master-Carr is your friend. I think the length is about 30 on the muffler studs. I have to set some myself. https://www.mcmaster.com/threaded-studs |
milwlandrover |
Jun 14 2020, 03:41 PM
milwlandrover |
Jun 14 2020, 03:46 PM
email me at mwilde2@gmail and I can send 25 pictures
Lo-Fi Version | Time is now: 28th March 2024 - 11:28 PM |
