Engine Number Decipher |
SuperSquid |
Mar 31 2020, 05:45 PM
Newbie Group: Members Posts: 24 Joined: 26-February 20 From: Louisville Kentucky Member No.: 23,972 Region Association: South East States |
Getting ready to order a new top-end for my 914 and have a few questions. Based on my engine number and heads this is a 914 2.0, correct? I just do NOT want to order the wrong parts. I am worried the last owner might have used the incorrect parts. Thank you as always for your help.
Attached thumbnail(s) |
Mark Henry |
Mar 31 2020, 06:02 PM
Not 2.0 914 heads, they would be 3 intake bolts.
What's the number off of? Comes up fan shroud which doesn't help you. |
Mark Henry |
Mar 31 2020, 07:21 PM
Just noticed the rockers have hydraulic cam spacers, so there's a chance it's a bus engine, but you won't know for sure till you pop the heads off.
SuperSquid |
Mar 31 2020, 07:26 PM
I think I found the correct engine number on the block. So is it a 1.8? Thank again for your help.
Bleyseng |
Mar 31 2020, 07:27 PM
Pull a lifter out and see if it's hydraulic vs solid.
iankarr |
Mar 31 2020, 07:28 PM
The wrencher formerly known as Cuddy_K Group: Members Posts: 2,472 Joined: 22-May 15 From: Heber City, UT Member No.: 18,749 Region Association: Intermountain Region |
@Mark Henry is the man. He'll help you get to the bottom of this.
SuperSquid |
Mar 31 2020, 08:18 PM
Adding a few more pics. Trying to solve the problem of what type of engine is this and what piston kit/size do I need to order. Thanks again for your help and advice.
sixnotfour |
Mar 31 2020, 08:45 PM
914 Wizard Group: Members Posts: 10,423 Joined: 12-September 04 From: Life Elevated..planet UT. Member No.: 2,744 Region Association: Rocky Mountains |
021 101 371 S 1.8 Bus
(IMG:style_emoticons/default/beerchug.gif) 021 101 371 1.7 021 101 371 J 1.7 021 101 371 Q 1.7 021 101 371 Q 1.7 021 101 372 1.7 022.101.353 B 1.7 914 022.101.351 A 1.7 914 021 101 371 H 1.8 Bus 021 101 371 S 1.8 Bus 022 101 351 C 1.8 914 US 021 101 351 S 1.8 914 "Euro" 022 101 372 G 2.0 Bus 071 101 372 A 2.0 Bus; different exhaust ports 071 101 372 B 2.0 Bus; different exhaust ports 039 101 351 E 2.0 914 73-74 039 101 351 G 2.0 914 75-76 |
SuperSquid |
Mar 31 2020, 08:52 PM
Wow, thank you so much. Any idea how my 914 ended up with a VW bus engine? Looks like the 1.8 bus piston kits are less expensive. Any advice on what piston kit I should order? I would love to get a little more performance. Thanks
Bleyseng |
Mar 31 2020, 10:02 PM
Order 96mm flat tops for a 1.8l 914 as you have 66mm rods so you need the ones with the right wrist pin height. Those heads atleast have the bigger valves than the 2.0l bus heads
porschetub |
Mar 31 2020, 10:57 PM
Wow, thank you so much. Any idea how my 914 ended up with a VW bus engine? Looks like the 1.8 bus piston kits are less expensive. Any advice on what piston kit I should order? I would love to get a little more performance. Thanks Many get caught like that,common enough,your heads will have small valves so unless you change to 914 type you will have limited potential,go to 96mm barrels and pistons if doing top-end build and gain a small power increase,get the higher compression ones as bus ones are like 7.3 to 1 to handle the load they push along. |
Lo-Fi Version | Time is now: 7th May 2024 - 06:12 PM |
