1975 Porsche 914 1.8 Smog Removal / what to keep, 1975 1.8l-Smog removal list and what to keep |
1975Porsche914 |
Apr 1 2020, 08:41 PM
Newbie Group: Members Posts: 12 Joined: 1-April 20 From: Orange County, CA USA Member No.: 24,088 Region Association: Southern California |
Hello,
My son and I have a 1975 Porsche 914 1.8l. Has the same stock fuel injection. Been sitting in the garage for years, but want to revive it. So far, took the gas tank out, getting professionally cleaned and sealed, all the rubber hoses are shot, but the 2 plastic fuel lines appear to be good. Need advice on just about everything, but engine issues first. 1. Removing all the 1975 smog items. Not sure what exactly what smog items to take off and and what should be only be remaining to run the fuel injection. Step by step instructions would be good. 2. Seals and gaskets to replace. 3. Pulled off the old heat exchangers and old Ansa exhaust, to replace with a header and muffler. 4. Air cleaner improvements? 5. Performance upgrades. Suggestions welcome ! |
ndfrigi |
Apr 1 2020, 10:01 PM
Maltese Falcon |
Apr 1 2020, 10:03 PM
Advanced Member Group: Members Posts: 4,634 Joined: 14-September 04 From: Mulholland SoCal Member No.: 2,755 Region Association: None |
Father & Son projects are (IMG:style_emoticons/default/first.gif) and (IMG:style_emoticons/default/welcome.png) !
abes914 |
Apr 1 2020, 10:26 PM
Member Group: Members Posts: 366 Joined: 30-March 11 From: Long Beach Member No.: 12,880 Region Association: Southern California |
Although the plastic lines seems fine, I would replace them with stainless steel lines. Tangerine racing sells them and a local guy from la also (sorry I forgot his name). Most seals and rubbers that I replaced are from 914rubber.com There are plenty of folks from so cal that always happy to lend their hands but will have to wait for that until we get rid of this cov19. And a lot of helpful folks here in the 914world. Congrats! P.S. We love pictures (IMG:style_emoticons/default/beerchug.gif) |
ndfrigi |
Apr 1 2020, 10:31 PM
(IMG:style_emoticons/default/welcome.png) Although the plastic lines seems fine, I would replace them with stainless steel lines. Tangerine racing sells them and a local guy from la also (sorry I forgot his name). Most seals and rubbers that I replaced are from 914rubber.com There are plenty of folks from so cal that always happy to lend their hands but will have to wait for that until we get rid of this cov19. And a lot of helpful folks here in the 914world. Congrats! P.S. We love pictures (IMG:style_emoticons/default/beerchug.gif) Local member who supply SS fuel lines his name is Robert @Rotary’14 |
Coondog |
Apr 2 2020, 06:35 AM
Advanced Member Group: Members Posts: 2,089 Joined: 24-September 15 From: Apple Valley Calif Member No.: 19,195 Region Association: Southern California |
You may want to rethink the replacement of your heat exchangers. It does get cold in OC.
Let’s brake it down what putting on headers and losing your HE will give you. PROs.... maybe your going to gain a few HP out of a older crap 1.8 engine that’s probably giving you 65-70 RWHP. CONs.... You just spent a lot of money for a few HP You will get cold and driving without a defroster sucks Car will be louder. Which in my opinion is stupid if you don’t have the HP to back it up Replace your fuel lines, get your car to be 100% mechanically safe. Listen to your local OC 914 brothers, they are some of the most knowledgeable 914 peeps I have met and read everything in the Lapuwali Classic Thread Forum. |
Cairo94507 |
Apr 2 2020, 07:42 AM
Michael Group: Members Posts: 9,711 Joined: 1-November 08 From: Auburn, CA Member No.: 9,712 Region Association: Northern California |
(IMG:style_emoticons/default/welcome.png) Yes, welcome to the madness. Coondog hit the nail on the head. (IMG:style_emoticons/default/beerchug.gif)
ConeDodger |
Apr 2 2020, 07:59 AM
Apex killer! Group: Members Posts: 23,558 Joined: 31-December 04 From: Tahoe Area Member No.: 3,380 Region Association: Northern California |
Is it a California 914? If so, there is more smog than 49 state. Keep the parts as someone with a ‘76 might need them to pass the smog test. You’ll need to seal the heads after removing the pump. I’ve heard it’s NPT but not sure. Other than that, it’s not much different than the 49 state cars. Your exhaust will eliminate the CAT.
abes914 |
Apr 2 2020, 11:59 AM
Instead of headers and exhaust, why not backdate to older heat exchange system? They will flow better, less weight and keep you heat too.
[insert shameless promotion here] I have a 73 1.7 heat exchanger with most of heat tubes (I think) for cheap. Just need heat exchange support and muffler. just something to ponder. |
dr914@autoatlanta.com |
Apr 2 2020, 12:00 PM
914 Guru Group: Members Posts: 7,816 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None |
I would leave it stock and not "pull" anything off!!!!!!
Hello, My son and I have a 1975 Porsche 914 1.8l. Has the same stock fuel injection. Been sitting in the garage for years, but want to revive it. So far, took the gas tank out, getting professionally cleaned and sealed, all the rubber hoses are shot, but the 2 plastic fuel lines appear to be good. Need advice on just about everything, but engine issues first. 1. Removing all the 1975 smog items. Not sure what exactly what smog items to take off and and what should be only be remaining to run the fuel injection. Step by step instructions would be good. 2. Seals and gaskets to replace. 3. Pulled off the old heat exchangers and old Ansa exhaust, to replace with a header and muffler. 4. Air cleaner improvements? 5. Performance upgrades. Suggestions welcome ! |
914werke |
Apr 2 2020, 12:24 PM
"I got blisters on me fingers" Group: Members Posts: 9,999 Joined: 22-March 03 From: USofA Member No.: 453 Region Association: Pacific Northwest |
If you do decide to continue down this path, Ive been seeking one of those parts, HERE the grey pipe in the picture posted (IMG:style_emoticons/default/bye1.gif)
JeffBowlsby |
Apr 2 2020, 01:24 PM
914 Wiring Harnesses Group: Members Posts: 8,477 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None |
1975Porsche914 |
Apr 3 2020, 12:47 PM
Is it a California 914? If so, there is more smog than 49 state. Keep the parts as someone with a ‘76 might need them to pass the smog test. You’ll need to seal the heads after removing the pump. I’ve heard it’s NPT but not sure. Other than that, it’s not much different than the 49 state cars. Your exhaust will eliminate the CAT. Hello, yes it is a CA 1975 Porsche 914, 1.8l I will keep the smog stuff that is still good. Now I am looking for an exact direction of what exactly to pull off, and what to keep on a no smog 49 state 1.8l car. Pictures. |
1975Porsche914 |
Apr 3 2020, 12:49 PM
1975Porsche914 |
Apr 3 2020, 12:52 PM
(IMG:style_emoticons/default/welcome.png) Although the plastic lines seems fine, I would replace them with stainless steel lines. Tangerine racing sells them and a local guy from la also (sorry I forgot his name). Most seals and rubbers that I replaced are from 914rubber.com There are plenty of folks from so cal that always happy to lend their hands but will have to wait for that until we get rid of this cov19. And a lot of helpful folks here in the 914world. Congrats! P.S. We love pictures (IMG:style_emoticons/default/beerchug.gif) I agree, think changing all the fuel lines should be changed. I think I may need a list of what should be gone with no smog and what it looks like, and what the 1.8l should look like de-smogged. |
1975Porsche914 |
Apr 3 2020, 12:54 PM
You may want to rethink the replacement of your heat exchangers. It does get cold in OC. Let’s brake it down what putting on headers and losing your HE will give you. PROs.... maybe your going to gain a few HP out of a older crap 1.8 engine that’s probably giving you 65-70 RWHP. CONs.... You just spent a lot of money for a few HP You will get cold and driving without a defroster sucks Car will be louder. Which in my opinion is stupid if you don’t have the HP to back it up Replace your fuel lines, get your car to be 100% mechanically safe. Listen to your local OC 914 brothers, they are some of the most knowledgeable 914 peeps I have met and read everything in the Lapuwali Classic Thread Forum. Ok, I think the "back dating" of the heat exchangers is a good idea. I agree, I intend to replace all the fuel lines. Thank you ! |
1975Porsche914 |
Apr 3 2020, 12:56 PM
Is it a California 914? If so, there is more smog than 49 state. Keep the parts as someone with a ‘76 might need them to pass the smog test. You’ll need to seal the heads after removing the pump. I’ve heard it’s NPT but not sure. Other than that, it’s not much different than the 49 state cars. Your exhaust will eliminate the CAT. Yes, it is a 1975 Porsche 914 1.8l CA car. I will keep the parts. What is the best way to "seal the heads" ? So what are some of the best exhaust systems ? Need help on making a 49 state car. Thanks.. |
Apr 3 2020, 01:37 PM
914-6 GT in waiting Group: Members Posts: 19,238 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
Stainless steel heat exchangers and one of Ben’s / MB911 stainless steel mufflers.
@MB911 |
911GT2 |
Apr 3 2020, 03:06 PM
Member Group: Members Posts: 195 Joined: 2-March 11 From: The Netherlands Member No.: 12,773 Region Association: Europe |
Lo-Fi Version | Time is now: 24th April 2024 - 11:08 PM |
