Non-model year changes |
356drb |
Apr 4 2020, 02:50 PM
Newbie Group: Members Posts: 43 Joined: 4-April 20 From: Indianapolis Member No.: 24,101 Region Association: None |
Hi!
I'm updating my 914 Authenticity book and the new edition will contain all color images, which will also be available online, on demand. New chapters on brakes/suspension/gearbox and engine have been written and all other chapters have been revised and are out for technical proofing. Hope to have it out late this summer, if I can get photos. There are a number of changes that are noted in the parts manuals which do not align with model years. I would like to put months and years on these changes and am hoping that you can help define them. At this time the Porsche archives has been able to only do this on one of them. I have put them in chronological order and nearly all of them occur during the 1973 model year. The numbers on the left are the Porsche modification number in the parts manuals. The ones without these are still listed in the parts manuals with chassis numbers when the change occurs. Formatting suffered a little from conversion from Word. I can't fix it -- I tried. Since US spec. cars have month and year on that sticker on the door jamb and some of you may have the actual production date, can you take a look and let me know if you have a chassis number close to these? Also, just because it says things change in the parts manuals, it doesn't mean that it is right, so if you think you know better, please let me know. It helps if you have an authentic car to back you up. Always remember one of my authenticity truisms though, " just because it is old and was on the car when you bought it, doesn't mean it is original." I'm also looking for people with authentic cars willing to take photos (authentic doesn't mean show quality). I can send a master list to anyone who wants one. I am particularly looking for 1970-1972 914-4s with painted bumpers and Euro spec. cars of all models. Please contact me directly at: 356drb@indy.net Modification # 4/2 from model 72 -- 914 243 0040/472 290 9017 Door panel (int.) 4/4 from model 72 -- 472 291 9033 A-frame/front shock/rotor/caliper 6/14 from model 73 -- 473 290 6861 from model 73 – 473 290 8292 US headlight upgrade 6/2 from model 73 -- 473 291 0937 rear inner wheel case USA w/ protection rail 6/1 from model 73 -- 473 291 2511 Cap for front wheel hub/front rotor w/ring 6/4 from model 73 -- 473 291 7851 6/8 from model 73 -- 473 291 8797 Covering for roll bar padding (int.) 6/6 from model 73 -- 473 291 8919 March 1973 Threshold/carpet rails, black 6/10 from model 73 -- 473 292 4929 Fresh air vent grille added 6/12 from model 73 -- 473 292 4903 Fuel tank 6/16 from model 73 -- 473 292 6222 Top/headliner/front edge profile/rear seal 6/18 from model 73 -- 473 292 7160 from model 74 -- 474 290 2454 Black washer jets 8/2 from model 74 -- 474 291 5752 Brake pressure regulator Thanks! Brett Johnson |
JeffBowlsby |
Apr 8 2020, 06:16 PM
914 Wiring Harnesses Group: Members Posts: 8,492 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None |
Terrific to find you here Brett.
Will you also include in the update: * A complete list/content of all 914 service bulletins, recall campaigns, model numbers? * The VIN when the change of the chassis number location occurred from being stamped into the rear trunk, to a plate riveted to the front trunk side rail? * A complete list of all factory publications - Manuals, electrical diagrams, service and training manuals, paint/fabric sample books etc. * Was there ever really a convex glass, passenger side mirror? * Were there any specific wiring harnesses to non-USA markets? i.e. the european cars had no sidemarkers, were the wires simply cut off from USA market chassis harnesses or was it a separate harness. The 1973 and 74-76 USA cars had seatbelt circuitry that the ROW cars did not have. Different wiring harnesses? Do you also have an interest in identifying/researching and including, other changes that are not documented in the parts manual? Especially by VIN number and part number) of when the change occurred (where possible)? Off the top of my head, certainly there are more: 1. In the 1972 model mid-year, the TPS changed from 4 pole to 5 pole, including the fuel injection harness. 2. In the 1971 model mid-year there were two USA chassis harnesses. The 1970-early 1971 has a 12 pole connection at the steering column, the later 1971 harness has 14 pole connection. This change also affects the steering column assembly itself which changed at the same time and has the mate to the 14 pin connector. I've found PNs but the realted harness VIN numbers vary from the steering column numbers. Glad you are here! Post it here if you need anything. |
Lo-Fi Version | Time is now: 9th May 2024 - 06:53 AM |
