Tube Chassis Subaru Engine build, Lots of new progress |
tazz9924 |
Apr 4 2020, 11:27 PM
Senior Member Group: Members Posts: 703 Joined: 31-May 15 From: Mooresville NC Member No.: 18,779 Region Association: None |
Heres the quick break down: My old car got totaled on the side of the road, i got a good settlement out of it and with the money im building A tube frame chassis 914 with Porsche Boxster suspension and a subaru turbo motor.
The goals: (Disclaimer some of these are really down the road and may not make the initial version 2.0, maybe 2.1 or so on and so forth. They are also goals so weather or not i achieve them, it’s something to shoot for.) Tube frame chassis, all made of DOM tube and when all when the car is fully built it should weigh 1600 ish lbs. The motor: It will have a subaru turbo motor. The initial version will see a 2.0 just so i can start having fun but eventually it’ll be a hybrid 2.5 making 400whp The suspension: It will all be porsche boxster same with the brakes so it should handle all the power and lack of weight im throwing at it. The body: It will be all fiberglass panels dzused on with the exception of the A pillar which will be a stock piece from a 914 but it will retain a vin tag. The only other stock 914 related thing will be pop up headlights which will be retained. Aero: This thing will have an extreme aero package. From the smooth underbelly with large rear diffuser and front splitter to canards and a chassis mounted rear wing, This “car” WILL have a presence like little else. Interior: Skip... JK this thing will have a digital dash, k tuned shifter, willwood pedal cluster, and a plaid racing seat. Thats about it, passenger seat is seen as optional at this point. So hopefully this should be good, i dont have much time, even in the covid 19 world we currently find ourselves in right now. It may not be a fast paced build but the goal is to have a roller by june... So lets get to building! OG car: The Crash: Whats Left: I dont have many parts left, I took all the good parts off sold what i could and kept what i needed. |
tazz9924 |
Jun 26 2020, 08:39 PM
Ill admit im a little stumped... Call it: i want to make the best decision but require the input of others to feel comfortable. So i need to mount the rear subframe but unlike most of the stages so far this to me seems less obvious. My big issue is how to best mount it when the mounting plate is 90 degrees to the direction my bars are coming at. Heres a picture of what im dealing with: (the red highlights are the subframes mounting spots)
I also have a nifty drawing showing where the trans will sorta sit when its on: My initial reaction is to add a bent tube meeting up with the bottom of the main hoop and some tubes linking the bar above it with the bent tube shown: Alternatively i could add a tube with just a 90 bend in it meeting up maybe 6 inches lower than the parallel bar above it kinda like this with some more reinforcement tubes: This is my dilema, any input is appreciated. Even just linking someone engineeringly minded would help my cause! @Carbon-14 ? |
76-914 |
Jun 26 2020, 10:41 PM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,490 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
Ill admit im a little stumped... Call it: i want to make the best decision but require the input of others to feel comfortable. So i need to mount the rear subframe but unlike most of the stages so far this to me seems less obvious. My big issue is how to best mount it when the mounting plate is 90 degrees to the direction my bars are coming at. Heres a picture of what im dealing with: (the red highlights are the subframes mounting spots) I also have a nifty drawing showing where the trans will sorta sit when its on: My initial reaction is to add a bent tube meeting up with the bottom of the main hoop and some tubes linking the bar above it with the bent tube shown: Alternatively i could add a tube with just a 90 bend in it meeting up maybe 6 inches lower than the parallel bar above it kinda like this with some more reinforcement tubes: This is my dilema, any input is appreciated. Even just linking someone engineeringly minded would help my cause! @Carbon-14 ? Pm curbandgutter. I was just talking to him about your car. He is finished with his tube frame build. Well that portion any way. His is stretched and widened. Rudy is his name @Curbandgutter |
Lo-Fi Version | Time is now: 24th April 2024 - 07:21 PM |
