Hollow vs rolled crush washer, Specifically for taco plate |
Highland |
Apr 6 2020, 04:04 PM
Senior Member Group: Members Posts: 513 Joined: 8-August 11 From: San Diego, CA Member No.: 13,418 Region Association: Southern California |
Wondering if anybody has an opinion on using a solid M6 copper crush washer in lieu of the hollow one from the kit for the oil temp sender plate. Does it make a difference or will the solid one over torque the boss to get a crush?
Does the same hold true for the oil screen plate? Would a sealing washer (the metal/rubber ones found on modern cars) be better? |
bdstone914 |
Apr 6 2020, 09:31 PM
bdstone914 Group: Members Posts: 4,522 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
@Highland
date='Apr 6 2020, 03:04 PM' post='2801550'] Wondering if anybody has an opinion on using a solid M6 copper crush washer in lieu of the hollow one from the kit for the oil temp sender plate. Does it make a difference or will the solid one over torque the boss to get a crush? Does the same hold true for the oil screen plate? Would a sealing washer (the metal/rubber ones found on modern cars) be better? [/quote] The late Cap'n Krusty ( John Larson) said the original washers were copper and asbestos. I would go with the hollow ones. What kit is it you have? The center plate uses a single center bolt with low torque. I think it uses an aluminum crush washer. I prefer aluminum as it is softer than copper. Bruce |
Lo-Fi Version | Time is now: 19th May 2024 - 12:33 AM |
