Chasing Exhaust Leaks, This is maddening, so many issues. |
ctc911ctc |
Apr 7 2020, 02:56 PM
Senior Member Group: Members Posts: 892 Joined: 9-June 18 From: boston Member No.: 22,206 Region Association: North East States |
All,
'74 914, 2L, original engine - about 20K miles I started a new thread because the ones I could find did not address this issue. Perhaps it is me???? Last month I purchased new gaskets (thanks Mark @914R) and annealed them as per instructions. Used super glue to stick them in place. Mounted the heat exchanger/manifold and locked them in with around 20lbs of torque. Copper goo on the nuts, etc. When I started the car it was the sound of my youth - smooth, strong,,,,,,ahh After a few days the sound changed, using a rubber tube held to my ear I found exhaust leaks in the junction to the muffler (used new gaskets, alum sandwiched ones). Here are the leaks Copper Gasket Leaks Seems as if the nuts were not tight enough. I made certain that the edge of the pipes were square and both on the same plane. Questions as to the copper gaskets: 1. Seems that one was not seated concentrically with the pipe, that exhaust was leaking from day one - is there a method to square this or center it? 2. the other gasket it seems did not get seated at all, so it seems as if it was concentric just not tight enough????? Now the aluminum Gaskets I really tightened the bolts, I have ordered new gaskets and am brushing smooth the flanges which were both kind of cruddy, any advice as to installing these? THANK YOU TEENERS! |
MartyYeoman |
Apr 7 2020, 08:35 PM
Senior Member Group: Members Posts: 1,518 Joined: 19-June 03 From: San Ramon, CA Member No.: 839 Region Association: Northern California |
You might want to check that the bolt mounting loops aren't bottoming out before the mounting faces (pipe end and copper gasket) seat properly. I had to file mine to create some necessary clearance. Just say'n.
IronHillRestorations |
Apr 8 2020, 10:40 AM
I. I. R. C. Group: Members Posts: 6,717 Joined: 18-March 03 From: West TN Member No.: 439 Region Association: None |
You might want to check that the bolt mounting loops aren't bottoming out before the mounting faces (pipe end and copper gasket) seat properly. I had to file mine to create some necessary clearance. Just say'n. This jogged my memory of another car I had in with non OE exhaust studs that were a bit too long to torque the exhaust nuts on two cylinders. It had some washers stacked to compensate. It was a low budget situation, and I wasn't going to pull the exhaust studs and open a can of worms |
Lo-Fi Version | Time is now: 15th May 2024 - 05:35 AM |
