FS Misc Parts for 914/912E/911, Excess Project parts, most new 50% off original OBO |
Bulldog9 |
Apr 7 2020, 03:33 PM
Senior Member Group: Members Posts: 705 Joined: 21-August 13 From: United States Member No.: 16,283 Region Association: MidAtlantic Region |
Using the downtime to clear out some of my leftover parts. All parts unless noted are new and never installed or run. Prices are + shipping. All prices are less than 50% off MSRP, but willing to deal, bundle and move these parts.
UPDATED TO REFLECT SOLD PARTS PM for pictures and details, or more information. 911/912E URO Rear glass weather strip - $25.00 911/912E Porsche Rear Engine Compartment Seal - $25.00 912E Exhaust Gaskets (OEM Porsche #923 11 151 01+C201) - $20.00 911/912E Transmission Mounts (2) - $25.00 *test fit installed, never run. I went with sport mounts instead 911 Front door harness and door wiring dust caps - $10.00 *Used, taken from door of an 86 Carrera 914 Alternator Cooling Plate (2) - $10.00 *Used, good condition 3 POD Plastic 2" VDO Gage Holder - $5.00 2" 12V VDO Clock - $35.00 *test fit installed, ended up using original 911 Heat and volume (control) missing fan switch - $5.00 Used from salvage 911 Headliner Tension Wires 1-4 - $30.00 914 Reman Alternator New never installed - $75.00 SOLD CB Performance Cross Bar Throttle Linkage Pack - Includes Steel Hex Cross Bar - 20 5/8" - $50.00 SOLD 911/912E Front glass weather strip (OEM Made in Germany) - $50.00 SOLD 912E/914 CB Performance Air Filters/Bases with hardware - $25.00 *test fit installed, never run. I went with a pulley system instead. SOLD SCAT bell crank Throttle control linkage - $40.00 *test fit installed, never run. I went with a pulley system instead. SOLD 912E/914 Original Customs Throttle Cable Bracket - $10.00 SOLD 912 E Bursch Exhaust (C 1990) New never installed - $225.00 SOLD 914 Sachs Throwout bearing and bushing caps - $50.00 SOLD NOS Bosch distributor cap and rotor kit (extra cap/condenser) -$10.00 **Fits stock distributor. Truly NOS, is in plastic display package. Will also throw in an extra cap and condenser. I am running the Pertronix plug and play (large distributor) SOLD Set of Lemforder Tie Rod Ends 10710 03 009 - $25.00 **NEW IN BOX. This is for the stock rack and tie rods. I went with the turbo rack which uses different tie rods. SOLD 912E/914 Bosch Fuel Pressure Regulator (Porsche box) - $70.00 SOLD 911/912E Clutch Pedal Return Spring - $5.00 SOLD |
stevegm |
Apr 7 2020, 03:53 PM
Advanced Member Group: Members Posts: 2,111 Joined: 14-July 14 From: North Carolina Member No.: 17,633 Region Association: South East States |
I will take all of the parts that fit a ‘67 912. I will look at the list closer. I just need to figure out which ones will fit.
Literati914 |
Apr 7 2020, 04:04 PM
Senior Member Group: Members Posts: 1,428 Joined: 16-November 06 From: Dallas, TX Member No.: 7,222 Region Association: Southwest Region |
I'll take the throttle bracket, tie rod ends, &...
Literati914 |
Apr 7 2020, 04:06 PM
..oh yea, gauge pod too.
Jack Standz |
Apr 7 2020, 05:47 PM
Member Group: Members Posts: 265 Joined: 15-November 19 From: Happy Place (& surrounding area) Member No.: 23,644 Region Association: None |
Hi, I'm interested in the following two items, but want the alternator if it is a Bosch and the T/o bearing if new. Photos would be nice if you send. Thanks.
PM for pictures and details, or more information. 914 Sachs Throwout bearing and bushing caps 914 Reman Alternator New never installed - $75.00 |
Literati914 |
Apr 8 2020, 07:29 PM
Pm sent.
Bulldog9 |
Apr 9 2020, 07:26 AM
Hi, I'm interested in the following two items, but want the alternator if it is a Bosch and the T/o bearing if new. Photos would be nice if you send. Thanks. PM for pictures and details, or more information. 914 Sachs Throwout bearing and bushing caps 914 Reman Alternator New never installed - $75.00 Sent a PM, but yes the T/O bearing is new, never installed. The Alternator is from E-Bay seller BNR parts, and was the high output version. I can't see a difference, but will go out to the garage and see if it says Bosch anywhere on it. |
bdstone914 |
Apr 9 2020, 08:48 AM
bdstone914 Group: Members Posts: 4,508 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
@stevegm
' date='Apr 7 2020, 02:53 PM' post='2801877'] I will take all of the parts that fit a ‘67 912. I will look at the list closer. I just need to figure out which ones will fit. [/quote] Not many. Big difference between a SWB 912 and a 912E |
ndfrigi |
Apr 9 2020, 09:26 AM
Advanced Member Group: Members Posts: 2,926 Joined: 21-August 11 From: Orange County Member No.: 13,474 Region Association: Southern California |
pm sent for 3 items
stevegm |
Apr 9 2020, 04:22 PM
[quote name='bdstone914' date='Apr 9 2020, 10:48 AM' post='2802424']
@stevegm ' date='Apr 7 2020, 02:53 PM' post='2801877'] I will take all of the parts that fit a ‘67 912. I will look at the list closer. I just need to figure out which ones will fit. [/quote] Not many. Big difference between a SWB 912 and a 912E [/quote] I know. Really, I don’t think there are any parts that will fit my car. Maybe the Transmission Mounts? |
Bulldog9 |
Apr 10 2020, 06:52 AM
Updated list to reflect parts sold.
stevegm |
Apr 10 2020, 08:34 AM
Does anybody know if the tranny mounts will work on a '67 912?
Apr 10 2020, 08:57 AM
914-6 GT in waiting Group: Members Posts: 19,223 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
Does anybody know if the tranny mounts will work on a '67 912? Steve - This PET site is one of the best for showing parts for Porsche cars. https://nemigaparts.com/cat_spares/pet/porsche/911-1/573u/ @stevegm |
stevegm |
Apr 10 2020, 09:15 AM
Does anybody know if the tranny mounts will work on a '67 912? Steve - This PET site is one of the best for showing parts for Porsche cars. https://nemigaparts.com/cat_spares/pet/porsche/911-1/573u/ @stevegm Thanks. I was just working on that. I don't think anything here will fit. |
Bulldog9 |
Apr 11 2020, 08:54 AM
**ALL PARTS that I have received payment for have been shipped. USPS priority boxes. Delivery is supposed to be Monday or Tuesday April 13 or 14.
malcolm2 |
Jul 7 2020, 08:27 PM
Advanced Member Group: Members Posts: 2,738 Joined: 31-May 11 From: Nashville Member No.: 13,139 Region Association: South East States |
ALT cooling plate????
Is that the plastic cover that kinda seals up the opening on the pulley side? I also need the curved ALT bracket. You got that? Clark |
Mikey914 |
Jul 9 2020, 07:27 PM
The rubber man Group: Members Posts: 12,638 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
I'll take the headliner tension wires. zip is 97124
Just let me know where to pay |
Lo-Fi Version | Time is now: 19th April 2024 - 07:27 PM |
