fasten your seatbelt + turnsignal dash lights |
dax1969 |
Apr 8 2020, 03:53 AM
Member Group: Members Posts: 360 Joined: 10-March 14 From: belgium Member No.: 17,103 Region Association: None |
Hi there, hope you're all safe and healthy...
I am still working on my dashlights of my 1974 and I have (again) some questions. With the ignition on my fasten your seatbelt light comes on but it also flashes together with my left/right turnsignals and hazard lights. I also have no left/right green arrow on the dash of my turnsignals (right one show a very weak blinking). I installed a new flasher relay and the only improvement I have is that I know have the blue high beam light. Unfortunately I could only get hold of the URO aftermarket part and someone suggested they can go bad. I will install an OEM one once Porsche shop is back in business. (btw, which brand is the OEM flasher relay ? Wehrle, Hella ? branded as Porsche ?). I also don't have the handbrake light on the dash.... I'll put a new switch and start fm there. Is there a way to test the switch ? Would door switches/interior lights (also not working) have any effect on the above ? Fuses (jwest fusebox)are ok and all ground have been cleaned. thks yr help and apologies for my perhaps stupid questions Dax |
StarBear |
Apr 8 2020, 07:36 AM
Senior Member Group: Members Posts: 1,856 Joined: 2-September 09 From: NJ Member No.: 10,753 Region Association: North East States |
Yes, those aftermarket flasher relays are all over the place; no two (even from the same producer) work the same way in my '74. They seem to cause the most problems in 74s for some reason.
NOS units are hard to find; wasn't aware that Porsche was making them; I think the older ones were made by Hella (Porsche part #914 618 303 11 or VW part #022-479-01; mine works best with ones having the Hella TBB264DB designation). BTW, "OEM" isn't OEM as we know it - it's a Chinese brand with the German flag as its logo - there was a thread about that about 2 weeks ago. |
Lo-Fi Version | Time is now: 3rd May 2024 - 08:38 AM |
