Crown and pinion wear patrern, Didn’t change pinion bearings , shims or paper gaskets |
panayotisnikas |
Apr 8 2020, 10:33 AM
Newbie Group: Members Posts: 25 Joined: 12-March 20 From: Greece Member No.: 24,021 Region Association: None |
Hello everybody , I just finished flipping my 914 gearbox to use in a beetle , I replaced 1st gear dog teeth and synchro ring , diff bearings , input shaft bearing . I set the preload for the diff , backlash is correct . I don’t think the engineering blue
I found is the best in the world because it’s hard to leave Marks on and kind of peels . I did my best to get a reading . I didn’t mess with the pinion bearing or it’s shims, neither with the paper gaskets between the case and the intermediate plate . So I wouldn’t expect having altered the pinion depth . Attached thumbnail(s) |
Lo-Fi Version | Time is now: 25th May 2024 - 03:19 AM |
