Another easy to do project GB Headlight sourounds w/ option for LED upgrade, YES we have white LEDs and H4 ENDS TOMORROW 4.30.20 |
Mikey914 |
Apr 24 2020, 06:17 PM
The rubber man Group: Members Posts: 12,638 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
PMs sent to all so far.
dakotaewing |
Apr 24 2020, 08:33 PM
Senior Member Group: Members Posts: 1,160 Joined: 8-July 03 From: DeSoto, Tx Member No.: 897 Region Association: Southwest Region |
@Mikey914
I also wanted the front turn signal screw set, but not seeing how to add it to my checkout... Please advise - Thanks |
jim_hoyland |
Apr 24 2020, 09:05 PM
Get that VIN ? Group: Members Posts: 9,263 Joined: 1-May 03 From: Sunset Beach, CA Member No.: 643 Region Association: Southern California |
White surrounds please... (IMG:style_emoticons/default/smile.gif)
Mikey914 |
Apr 24 2020, 09:21 PM
@Mikey914 I also wanted the front turn signal screw set, but not seeing how to add it to my checkout... Please advise - Thanks If |
dakotaewing |
Apr 24 2020, 09:45 PM
Hey @Mikey914 ,
Thanks for taking care of me, and the rest of the folks here on the World! (IMG:style_emoticons/default/beer.gif) I got the codes for the surrounds and the metal, but still looking for the turn signal screw set. If its not ready yet, I'll get them on the next order! Thom |
Mikey914 |
Apr 29 2020, 09:16 AM
The GB ends tomorrow midnight pacific
Mueller |
Apr 29 2020, 10:16 AM
I'd like to get a complete set in black. (surrounds, bulbs and lenses)
bobh |
Apr 30 2020, 07:18 AM
Newbie Group: Members Posts: 10 Joined: 26-March 13 From: Central Missouri Member No.: 15,697 Region Association: None |
I would like the complete set with lights in WHITE
Also want the complete GB package visor screws,lens screws, seals in amber |
Mikey914 |
Apr 30 2020, 08:10 AM
PMs set to all so far. So think about this we are only in the office til 5 if you want the codes you need us to send them to you. The codes expire at midnight. SO don't be shy if you want anything,
mark |
dlee6204 |
Apr 30 2020, 08:57 AM
I'm in.
Rob914 |
Apr 30 2020, 09:20 AM
Member Group: Members Posts: 113 Joined: 8-April 03 From: Lake Villa, IL Member No.: 541 Region Association: None |
One complete set (surrounds, lenses and lights) in black.
Thank you! |
ValcoOscar |
Apr 30 2020, 09:47 AM
Garage Life Group: Members Posts: 2,375 Joined: 19-November 13 From: SoCal Member No.: 16,669 Region Association: Southern California |
I'm in a FULL COMPLETE Set...in BLK Please.
PM Please Oscar |
frostyf |
Apr 30 2020, 04:37 PM
Member Group: Members Posts: 153 Joined: 27-March 14 From: VA 23455 Member No.: 17,168 Region Association: MidAtlantic Region |
So as many of you may have noticed we offered these up previously but as complete package to rebuild the entire assembly with the brushes and hardware. We really just needed to offer them up alone. So if you are tired of painting yours you can get new ones that will not peal. A little info on the whites we would like to share. When looking for samples we purchased 3 sets that were supposed to be original. The weird thing was they were all slightly different colors colors and one had texture to it. So we were initially thinking it was painted. This created a dilemma. DO we need 2 sets of molds for these? As we started to look closer at the other untextured ones we noticed that if we used acetone we could remove the color and they were in fact both painted. As we removed layers we found that both had texture. So we were able sand off the outer patina to match the color and produce these to look exactly like factory ones did new. The black is pretty straight forward and now if you want black for your yous and it "should" be white, you can swap them out no paint needed. (IMG:style_emoticons/default/biggrin.gif) Another thing you can do easily while you are there is to swap out the headlamp bulbs with housings and LED high low beam bulbs. We have been through countless vendors on these and have tested and run them in our cars. They are literally a safety issue if you drive at night you can really see the road. They re also adjustable so you can adjust the line for on coming traffic to no be blinded. There is an issue with high low circuits for grounding and we will be making a video of how to install, adjust and easily modify the circuit to run independently. These will be the base of the surrounds only (with new stainless screws), and option to add LED headlamps and housings. The latest version headlamps include new rubber seals on the back and when bough together WE assemble so you plug and play! headlight surrounds only are in black $50 in white $55 Add in LEDs with 2 new housings assembled and ready to plug in and your package is Black $135 White $140 (sorry got these reversed this is now corrected) Retail on these packages are $254 The reason we charge the $5 more is they actually cost more to make. So who's interested I have several other GBs going and we will combine to save shipping costs. This is just one of those easy to do projects that really make a difference. Retail is $164 for these alone Mark, If still available can I go for a Black Set please with LED bulbs . Thank you Nick |
Mikey914 |
Apr 30 2020, 07:05 PM
PMs sent to all so far, I will be back later tonight to check be codes expire at midnight
v82go |
Apr 30 2020, 08:43 PM
Resident Contrarian Group: Members Posts: 249 Joined: 9-December 04 From: Lakeland, Fl. Member No.: 3,250 |
One complete set (surrounds, lenses and lights) in black. Thank you! Bob |
mdelwiche |
Apr 30 2020, 10:15 PM
Vegas_914 Group: Members Posts: 59 Joined: 17-March 12 From: Tucson, AZ Member No.: 14,266 Region Association: Southwest Region |
If it’s not too late I’ll take a complete set in black!
Lo-Fi Version | Time is now: 27th April 2024 - 10:50 PM |
