Broken valve spring cylnder #4, Broken valve spring cylnder #4 |
vcolper |
Apr 13 2020, 09:35 AM
Newbie Group: Members Posts: 2 Joined: 2-February 19 From: Florida Member No.: 22,853 Region Association: South East States |
Question:
Can I replace a broken valve spring (Cyl 4) while engine is mounted in car? What tool? Recommendations? Thanks |
Jonathan Livesay |
Apr 13 2020, 10:05 AM
Senior Member Group: Members Posts: 740 Joined: 13-March 10 From: La Canada CA Member No.: 11,461 Region Association: None |
No. Unless you want to try to remove the cylinder head while the motor is in the car.
brant |
Apr 13 2020, 10:21 AM
914 Wizard Group: Members Posts: 11,603 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains |
I've done it.
you can build a tool that rocks on the rocker arm mounts... depresses the spring and allows everything to bolt back together brant |
Jack Standz |
Apr 13 2020, 10:59 AM
Member Group: Members Posts: 265 Joined: 15-November 19 From: Happy Place (& surrounding area) Member No.: 23,644 Region Association: None |
I've done it. you can build a tool that rocks on the rocker arm mounts... depresses the spring and allows everything to bolt back together brant Various vendors have them for sale...you can rent for $35... https://vwparts.aircooled.net/Type-4-Heavy-...l-tool-rent.htm |
Jonathan Livesay |
Apr 13 2020, 11:22 AM
I've done it. you can build a tool that rocks on the rocker arm mounts... depresses the spring and allows everything to bolt back together brant Various vendors have them for sale...you can rent for $35... https://vwparts.aircooled.net/Type-4-Heavy-...l-tool-rent.htm I stand corrected. (IMG:style_emoticons/default/pray.gif) |
crash914 |
Apr 13 2020, 11:39 AM
its a mystery to me Group: Members Posts: 1,826 Joined: 17-March 03 From: Marriottsville, MD Member No.: 434 Region Association: MidAtlantic Region |
you can always do the rope trick.. Fill the cylinder with sash cord, then use the hammer type Lisle tool to remove the keepers.
not a lot of room to swing a hammer, but it might work. Otherwise, do the other style... |
ClayPerrine |
Apr 13 2020, 11:56 AM
Life's been good to me so far..... Group: Admin Posts: 15,392 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille |
I have replaced valve springs on lots of engines with the engine assembled and in the car.
1. Make a tool that hooks to the rocker shaft to depress the spring. 2. Remove the rockers on both intake and exhaust valves on the cylinder that needs the spring changed. 3. Put your tool on the engine, and pressurize the cylinder with about 100 psi of compressed air. 4. Push down the spring and remove the keepers. 5. Carefully remove the tool and replace the spring. 6. Push the new spring down with the tool and reinstall the valve keepers. 7. Disconnect the air, and reinstall the rest of the parts you removed. 100PSI will hold the valve in the head. I know it works, I have replaced lots of valve stem seals, and springs that way. In fact, the type IV horizontally opposed engine makes it easier. If you lose air pressure, the valve won't fall into the cylinder. |
bretth |
Apr 13 2020, 12:24 PM
Senior Member Group: Members Posts: 899 Joined: 23-June 15 From: Central TX Member No.: 18,882 Region Association: Southwest Region |
I replaced valve seals on my old V8 Dodge years ago by taking out the spark plugs and then inserting a few feet of clean clothes line rope into the cylinder to fill up the combustion chamber so that the valve wouldn't fall into the head. I brought the piston up most of the way to TDC then pushed in a long length of new rope. When it seemed mostly full I would then turn the crank a little more by hand to tighten the mass of rope up against the valves and hold them in place. Then use a spring compression tool to remove the spring. When done then back the piston off again and just pull the rope out.
Jack Standz |
Apr 13 2020, 02:37 PM
Question: Can I replace a broken valve spring (Cyl 4) while engine is mounted in car? What tool? Recommendations? Thanks Now that we've come up with some ways "how" to fix the broken spring, can you let us in on "why" you have to replace this spring? Never had a 914 valve spring break. Have had valve seats let loose, burnt valves, etc. What's your take on this? Was there a valve train geometry problem? Badly manufactured spring? Just curious & good luck with the fix. |
vcolper |
Apr 15 2020, 09:34 AM
Hello,
First of all I want to thank you all for the responses and suggestions. A little history on the car: I purchased this 914 out of Virginia Beach VA, without seeing it in person. I live in North Port, FL so I had an old Navy buddy that lived close by have a look at it. According to him all looked good, even the hell hole. Started quickly and drove ok. So I purchased it. Got it home about 4-5 days later. Things weren't exactly as my buddy described. The car did start and run ok. Gas pedal was broken, so I replaced it. Placed car on my lift and saw the RUST and some bad repair job. I was very frustrated with the bad repair job of hell hole with mostly Bondo and some fiberglass. Later my buddy said he couldnt look under the car due to his bad back. So I parked the car for another day. I drove it frequently around the block and eventually decided to sell it. During a test drive the car lost power...that didnt go well with the interested buyer. Still ran but had low power, misfiring and very rough idle. Found no compression on cyl 4. Upon removing the valve cover found the cly 4 valve spring broken. I dont know why it broke. Havent figured out how to place a pic here. Ive worked on Vanagon and other vw engines before so I was just gonna replace the spring and test the outcome. I decided to drop the engine and repair it. Now that the engine is off I can see the nightmare of bondo, fiberglass and some sheet metal. The rust repair needed goes from the battery tray mount to the jack point and rocker. Ill be deciding what to do soon |
Mark Henry |
Apr 15 2020, 01:04 PM
Question: Can I replace a broken valve spring (Cyl 4) while engine is mounted in car? What tool? Recommendations? Thanks Now that we've come up with some ways "how" to fix the broken spring, can you let us in on "why" you have to replace this spring? Never had a 914 valve spring break. Have had valve seats let loose, burnt valves, etc. What's your take on this? Was there a valve train geometry problem? Badly manufactured spring? Just curious & good luck with the fix. Sometimes springs just break, but it's pretty rare on a stock engine. One thing to check is that you don't have a loose seat. Sometimes the seat can bounce back into it's seat bore, but there should be tell tale signs or it might even fall out when you remove the valve. If not cycle it through an oven, it will fall out when hot. Just don't heat a dirty head in the wife's kitchen range.... (IMG:style_emoticons/default/huh.gif) Run it through the dishwasher first! (IMG:style_emoticons/default/w00t.gif) |
HAM Inc |
Apr 15 2020, 04:04 PM
Senior Member Group: Members Posts: 846 Joined: 24-July 06 From: Watkinsville,GA Member No.: 6,499 Region Association: None |
Over the twenty plus years I worked with used T4 heads I saw a great many come in with a broken spring. The number one cause was rust. Engines that sit for an extended period of time have a problem with this.
Weak springs also are the number one cause of dropped valve seats on T4 heads. The springs are over 40 years old now. If one broke, the others can too. And I would bet my corona stimulus check they're all weak, even if they aren't rusty. |
gtbarnes |
Jun 3 2020, 11:17 PM
Newbie Group: Members Posts: 10 Joined: 9-July 13 From: nash,tn Member No.: 16,111 Region Association: South East States |
Hello, First of all I want to thank you all for the responses and suggestions. A little history on the car: I purchased this 914 out of Virginia Beach VA, without seeing it in person. I live in North Port, FL so I had an old Navy buddy that lived close by have a look at it. According to him all looked good, even the hell hole. Started quickly and drove ok. So I purchased it. Got it home about 4-5 days later. Things weren't exactly as my buddy described. The car did start and run ok. Gas pedal was broken, so I replaced it. Placed car on my lift and saw the RUST and some bad repair job. I was very frustrated with the bad repair job of hell hole with mostly Bondo and some fiberglass. Later my buddy said he couldnt look under the car due to his bad back. So I parked the car for another day. I drove it frequently around the block and eventually decided to sell it. During a test drive the car lost power...that didnt go well with the interested buyer. Still ran but had low power, misfiring and very rough idle. Found no compression on cyl 4. Upon removing the valve cover found the cly 4 valve spring broken. I dont know why it broke. Havent figured out how to place a pic here. Ive worked on Vanagon and other vw engines before so I was just gonna replace the spring and test the outcome. I decided to drop the engine and repair it. Now that the engine is off I can see the nightmare of bondo, fiberglass and some sheet metal. The rust repair needed goes from the battery tray mount to the jack point and rocker. Ill be deciding what to do soon I just had the same issue(rusted springs from sitting a long time) Just wondering if your valve was bent as a result. Mine broke at idle! Planning to put air pressure in it tomorrow and see. If it seals Im just going to replace all the springs with the in-car tool, I think! |
gtbarnes |
Jun 4 2020, 05:43 PM
Over the twenty plus years I worked with used T4 heads I saw a great many come in with a broken spring. The number one cause was rust. Engines that sit for an extended period of time have a problem with this. Weak springs also are the number one cause of dropped valve seats on T4 heads. The springs are over 40 years old now. If one broke, the others can too. And I would bet my corona stimulus check they're all weak, even if they aren't rusty. You are 1000% correct on ALL of that...Now the question is .."Where do you get 4cyl/typ4 valvespring set...or even ONE!!!!!?????ANYONE????HELP??? |
pilothyer |
Jun 4 2020, 06:10 PM
Member Group: Members Posts: 838 Joined: 21-May 08 From: N. Alabama Member No.: 9,080 Region Association: South East States |
[/quote]
You are 1000% correct on ALL of that...Now the question is .."Where do you get 4cyl/typ4 valvespring set...or even ONE!!!!!?????ANYONE????HELP??? [/quote] HERE FOR ONE |
maf914 |
Jun 5 2020, 09:36 AM
Webcam has type 4 spring sets:
http://www.webcamshafts.com/pages_vehicles...rsche/1691.html Aircooled.net has single springs: http://vwparts.aircooled.net/Valve-Spring-...21-109-623k.htm |
gtbarnes |
Jun 6 2020, 12:06 AM
[quote name='pilothyer' date='Jun 4 2020, 04:10 PM' post='2822080']
[/quote] You are 1000% correct on ALL of that...Now the question is .."Where do you get 4cyl/typ4 valvespring set...or even ONE!!!!!?????ANYONE????HELP??? [/quote] HERE FOR ONE [/quote] Thanks, had finally found a site that lists them, very little info and NO phone number. Ill see if they are actually IN stock at these other places. |
gtbarnes |
Jun 6 2020, 12:15 AM
Webcam has type 4 spring sets: http://www.webcamshafts.com/pages_vehicles...rsche/1691.html Aircooled.net has single springs: http://vwparts.aircooled.net/Valve-Spring-...21-109-623k.htm TY Yea I was aware of these places, full set non-performance was surprisingly more difficult to find |
gtbarnes |
Jun 6 2020, 12:24 AM
Hello, First of all I want to thank you all for the responses and suggestions. A little history on the car: I purchased this 914 out of Virginia Beach VA, without seeing it in person. I live in North Port, FL so I had an old Navy buddy that lived close by have a look at it. According to him all looked good, even the hell hole. Started quickly and drove ok. So I purchased it. Got it home about 4-5 days later. Things weren't exactly as my buddy described. The car did start and run ok. Gas pedal was broken, so I replaced it. Placed car on my lift and saw the RUST and some bad repair job. I was very frustrated with the bad repair job of hell hole with mostly Bondo and some fiberglass. Later my buddy said he couldnt look under the car due to his bad back. So I parked the car for another day. I drove it frequently around the block and eventually decided to sell it. During a test drive the car lost power...that didnt go well with the interested buyer. Still ran but had low power, misfiring and very rough idle. Found no compression on cyl 4. Upon removing the valve cover found the cly 4 valve spring broken. I dont know why it broke. Havent figured out how to place a pic here. Ive worked on Vanagon and other vw engines before so I was just gonna replace the spring and test the outcome. I decided to drop the engine and repair it. Now that the engine is off I can see the nightmare of bondo, fiberglass and some sheet metal. The rust repair needed goes from the battery tray mount to the jack point and rocker. Ill be deciding what to do soon Was wondering if you have took it apart yet? Was it broken from heavy rust spot on the valve spring and was the valve bent/tweeked? Hope its going well. |
gtbarnes |
Jun 6 2020, 12:13 PM
[/quote] You are 1000% correct on ALL of that...Now the question is .."Where do you get 4cyl/typ4 valvespring set...or even ONE!!!!!?????ANYONE????HELP??? [/quote] HERE FOR ONE [/quote] TY! |
Lo-Fi Version | Time is now: 18th April 2024 - 08:35 PM |
