> Rocker Arm Bolt Torque at TDC
amphiduck
post Apr 17 2020, 10:34 PM
I just replaced the pushrod tube seals on my '72 1.7 and wanted to verify that I torqued the rocker arms correctly. I torqued both 1 and 3 cylinders at TDC (rotor in distributor pointing at 12:00 on the notch) and #2 and 4 with roter at 3:00. Did I need to rotate the engine at all between 1&3 or 2&4? I torqued to 130 inch/pounds or almost 11 ft/lbs.
Thanks for the help, hope to adjust valves and replace valve cover gaskets tomorrow.
amphiduck   Rocker Arm Bolt Torque at TDC   Apr 17 2020, 10:34 PM
- Lo-Fi Version Time is now: 5th July 2025 - 12:33 AM
