How to remove wiper assembly |
Ed Evans |
Apr 20 2020, 09:05 PM
Newbie Group: Members Posts: 12 Joined: 15-August 17 From: Idaho Member No.: 21,348 Region Association: None |
What's the procedure to remove the wiper assembly / linkage / transmission?
I've removed the wipers and the washers on the top side of the cowl. I can get both wiper posts to dip a bit if I push on em from the top. I've also removed the nut inside the dash that holds the flexy-post thing. And...the thing won't budge. Well, not much anyway. Is there more to remove first? Cheers, Ed Evans 1974-nearly-stripped-husk-of-a-914 |
Rob-O |
Apr 21 2020, 09:04 AM
Senior Member Group: Members Posts: 1,252 Joined: 5-December 03 From: Mansfield, TX Member No.: 1,419 Region Association: Southwest Region |
Did you remove the gas tank and the fresh air box first? It doesn’t come out without those removed...
Ed Evans |
Apr 21 2020, 07:02 PM
Apr 21 2020, 09:02 PM
Pull motor towards front until stud that goes inside comes free.
Then twist down and out. |
Or, cut front of car off, it comes out much easier
cary |
Apr 21 2020, 10:08 PM
Lo-Fi Version | Time is now: 19th May 2024 - 07:03 AM |
