Lubricate Starter Solenoid |
TX914 |
Apr 21 2020, 05:12 AM
Alan-B Group: Members Posts: 168 Joined: 27-July 14 From: USA Member No.: 17,689 Region Association: None |
Does anyone have experience lubricating the solenoid on a SR17x starter? My starter is staying engaged for a few seconds after releasing the key on start. If it doesn't disengage after a couple of seconds, a blip on the throttle will do it, or sometimes, turning the car off and restarting works. Is it even possible to disassemble and lube the solenoid piston on a SR17x? Thanks, Alan B |
fixer34 |
Apr 21 2020, 06:31 AM
Senior Member Group: Members Posts: 1,085 Joined: 16-September 14 From: Chicago area Member No.: 17,908 Region Association: Upper MidWest |
I don't think you want to lube the electrical solenoid itself. Maybe try to clean/lightly lube the gear shaft itself.
Lo-Fi Version | Time is now: 19th May 2024 - 06:26 AM |
