| MM1 |
Jul 11 2020, 06:48 PM
914 obsession continues ![]() ![]() ![]() Group: Members Posts: 619 Joined: 9-May 18 From: Thousand Oaks, CA Member No.: 22,105 Region Association: Southern California
Pm sent for pressure plate
| Dominic |
Aug 1 2020, 10:47 PM
Dominic ![]() ![]() ![]() Group: Members Posts: 997 Joined: 14-January 03 From: Vacaville, CA Member No.: 149 Region Association: Northern California |
Bump!
| PotterPorsche |
Aug 2 2020, 08:19 AM
Member ![]() ![]() Group: Members Posts: 295 Joined: 10-November 13 From: Hayward CA Member No.: 16,628 Region Association: None |
Pm sent on piston and cylinders
| Charles Freeborn |
Aug 6 2020, 02:15 PM
Member ![]() ![]() Group: Members Posts: 345 Joined: 21-May 14 From: United States Member No.: 17,377 Region Association: Pacific Northwest |
I'd take the cylinders if they're within spec. No need for pistons.
-C |
| Dominic |
Aug 7 2020, 02:02 PM
I'd take the cylinders if they're within spec. No need for pistons. -C Charles, They can't be used for 94mm pistons, they are out of spec. I measured one of the barrels at 94.10mm, and the max is 94.018mm per the tech spec book. These are perfect to be honed out for 96mm pistons. A lot better than taking a chance with cheap Chinese cast barrels. Thanks, Dominic |
| Dominic |
Aug 15 2020, 05:26 PM
Bump!
| Dominic |
Aug 29 2020, 11:48 AM
BUMP!
| Dominic |
Sep 18 2020, 07:29 AM
Bump!
| Dominic |
Oct 4 2020, 03:20 PM
Bump!
| Dominic |
Nov 9 2020, 08:42 PM
Bump!
| Dominic |
Nov 21 2020, 01:39 PM
Bump!
| Dominic |
Dec 13 2020, 08:21 PM
Bump!
| Robarabian |
Dec 13 2020, 09:00 PM
914 A Roo ![]() ![]() ![]() Group: Members Posts: 745 Joined: 11-February 19 From: Simi Valley, Kalifornia Member No.: 22,865 Region Association: Southern California
Do you still have the side shift engine mount bar?
my zip is 93063.... |
| RestoReese |
Dec 17 2020, 01:14 AM
Newbie ![]() Group: Members Posts: 33 Joined: 29-June 19 From: Dallas, TX Member No.: 23,256 Region Association: Southwest Region |
I'll take the headlight surround if still available.
Lo-Fi Version | Time is now: 30th October 2026 - 11:37 AM |
