Cam Swap, Engine All Together |
dereknlee |
Apr 25 2020, 09:27 AM
Member Group: Members Posts: 63 Joined: 16-March 12 From: Shoreline, WA Member No.: 14,259 Region Association: Pacific Northwest |
I have a decision to make and could use some advice. My 1.7 engine was completely re-built into a 2 liter in 2012 by a local shop. At the time the plan was to run 40 IDFs so a Webcam 86 (00-152) cam was installed. My 914 hasn't driven since 2008 and has been an on-again/off-again project ever since, so the rebuilt long block has never run.
Well the 914 project is back on again and in the intervening years I've decided to stick with D-jet. I talked with Webcam, they said the 86 grind isn't too different but that they recommend a 73. And they generously offered to exchange for the cost of shipping (assuming the cam condition is as new). Swapping the cam is a bit intimidating as a project, but I have some engine rebuild experience and have done enough wrenching that I think I could muddle through. My questions are as follows: 1) If in my shoes would anyone not change the cam? My consensus from searching this forum is that the 73 is the grind to go with for injection and 86 is for carbs. But the conversations are usually had while someone is doing a rebuild anyway and looking for the optimal cam. 2) Is there a minimally invasive way to get to the cam, or should I just follow engine rebuild instructions and pull everything apart? Haven't found anything in my searches on this or other forums to suggest there is any option here. 3) Should I really just have a shop do this? The warranty on the rebuild has long expired. But the possibility for mistakes that could take down the otherwise good rebuild abound (or so I fear). Are there any steps in this process that require experience or special tools that someone who is book taught on this process is likely to mess up? Here's a picture, because walls of text are boring: (IMG:http://www.914world.com/bbs2/uploads_offsite/www.thesamba.com-14259-1587828462.1.jpg) Thanks! -Derek |
914werke |
Apr 27 2020, 06:42 PM
"I got blisters on me fingers" Group: Members Posts: 10,066 Joined: 22-March 03 From: USofA Member No.: 453 Region Association: Pacific Northwest |
My searches led me to believe that Djet would work on something as big as a 2056, with some adjustment. TRUE But I'm hearing that isn't the case for the 1.7L Djet (system). NOT EXACTLY TRUE So now I have an even harder decision to make than when I started this thread. Thanks all for the input! -Derek A simple change to 96mm P&C with net you 1911cc's or 1.9L, Fun Motor! (IMG:style_emoticons/default/aktion035.gif) Many of the components used on the 1.7L variaent of D-Jet can be used on a larger motor but to gain the most from the upgrade youll need to replace certain items & want to replace other key items. Think improved breathing & exhaust. If you have the OE 1.7L HE's & muffler there is one restriction you will want to remedy. On the intake side equally the 1.7L plenum intake & TB are going to be on the small side. Will it work? Yes, but not ideal. A better solution is to use the induction from the 2.0L Someone queried about your heads. VERY good point. depending on the heads you have/use will make the rest of your decisions easy or harder. With some patience & judicial shopping you can find the stuff (IMG:style_emoticons/default/rolleyes.gif) |
Lo-Fi Version | Time is now: 18th May 2024 - 11:53 AM |
