Cam Swap, Engine All Together |
dereknlee |
Apr 25 2020, 09:27 AM
Member Group: Members Posts: 63 Joined: 16-March 12 From: Shoreline, WA Member No.: 14,259 Region Association: Pacific Northwest |
I have a decision to make and could use some advice. My 1.7 engine was completely re-built into a 2 liter in 2012 by a local shop. At the time the plan was to run 40 IDFs so a Webcam 86 (00-152) cam was installed. My 914 hasn't driven since 2008 and has been an on-again/off-again project ever since, so the rebuilt long block has never run.
Well the 914 project is back on again and in the intervening years I've decided to stick with D-jet. I talked with Webcam, they said the 86 grind isn't too different but that they recommend a 73. And they generously offered to exchange for the cost of shipping (assuming the cam condition is as new). Swapping the cam is a bit intimidating as a project, but I have some engine rebuild experience and have done enough wrenching that I think I could muddle through. My questions are as follows: 1) If in my shoes would anyone not change the cam? My consensus from searching this forum is that the 73 is the grind to go with for injection and 86 is for carbs. But the conversations are usually had while someone is doing a rebuild anyway and looking for the optimal cam. 2) Is there a minimally invasive way to get to the cam, or should I just follow engine rebuild instructions and pull everything apart? Haven't found anything in my searches on this or other forums to suggest there is any option here. 3) Should I really just have a shop do this? The warranty on the rebuild has long expired. But the possibility for mistakes that could take down the otherwise good rebuild abound (or so I fear). Are there any steps in this process that require experience or special tools that someone who is book taught on this process is likely to mess up? Here's a picture, because walls of text are boring: (IMG:http://www.914world.com/bbs2/uploads_offsite/www.thesamba.com-14259-1587828462.1.jpg) Thanks! -Derek |
Mark Henry |
Apr 28 2020, 05:51 AM
Get a stock 2.0 intake system and run MS or SDS EFI
I've installed and tuned a fuel only SDS system in a weekend. I ran a basically stock engine and intake (2.0 Djet injectors) with SDS for a few years in my teen, ran like factory FI. |
Lo-Fi Version | Time is now: 18th May 2024 - 10:22 AM |
