Adjusting headlight front trim panel, Trying to get perfection! |
gturner008 |
Apr 26 2020, 08:11 AM
Member Group: Members Posts: 127 Joined: 21-April 20 From: Toronto Member No.: 24,163 Region Association: Canada |
Hello everyone. A newbie question.
I’m trying to work out how to adjust the position of the panel that sits in front of the headlights. Both are sitting too rearward of the hood and are slightly misaligned. How do you go about adjusting these? Many thanks. Gary |
FlacaProductions |
Apr 26 2020, 11:54 AM
Senior Member Group: Members Posts: 1,584 Joined: 24-November 17 From: LA Member No.: 21,628 Region Association: Southern California |
Are you referring to the "eyebrows" between the headlight covers and the bumper top?
If so, use "eyebrow" in the search - here's a few to get you started: http://www.914world.com/bbs2/index.php?sho...&hl=eyebrow http://www.914world.com/bbs2/index.php?sho...&hl=eyebrow http://www.914world.com/bbs2/index.php?sho...&hl=eyebrow http://www.914world.com/bbs2/index.php?sho...&hl=eyebrow http://www.914world.com/bbs2/index.php?sho...&hl=eyebrow |
porschetub |
Apr 26 2020, 05:57 PM
Hello everyone. A newbie question. I’m trying to work out how to adjust the position of the panel that sits in front of the headlights. Both are sitting too rearward of the hood and are slightly misaligned. How do you go about adjusting these? Many thanks. Gary These headlight covers have no adjustment,the headlights do however,these can be moved around a bit but don't expect perfect gaps on a car build in the 70's,good luck. |
gturner008 |
Apr 27 2020, 06:19 AM
Hello everyone. A newbie question. I’m trying to work out how to adjust the position of the panel that sits in front of the headlights. Both are sitting too rearward of the hood and are slightly misaligned. How do you go about adjusting these? Many thanks. Gary These headlight covers have no adjustment,the headlights do however,these can be moved around a bit but don't expect perfect gaps on a car build in the 70's,good luck. Thank you - that answered my question. The hood, fenders and lights are a perfect fit. Great shut lines. If the trim can’t be adjusted, I’ll live with the slight difference. Many thanks. Appreciate the post. |
North Coast Jim |
Apr 27 2020, 06:50 AM
Member Group: Members Posts: 323 Joined: 11-December 15 From: Northern Ohio Member No.: 19,450 Region Association: MidAtlantic Region |
I swapped out the 2 inner rubber fasteners for actual threaded fasteners with large flat washers. This now gives you yet another adjustment feature with the eyebrow. I must say the alignment I got is damn good.
Lo-Fi Version | Time is now: 16th May 2024 - 07:50 PM |
