Ampex351 |
Member ![]() ![]() Group: Members Posts: 104 Joined: 8-April 20 From: Roseburg, Oregon Member No.: 24,115 Region Association: Pacific Northwest ![]() |
I am sooooo glad I joined the group. You guys have been great with all your advice.
I'd like to know what you use for engine oil and tranny oil. My '73 has 88,000 miles. I'd like to say thank you in advance. Thanks, Roger |
porschetub |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,877 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None ![]() |
I am sooooo glad I joined the group. You guys have been great with all your advice. I'd like to know what you use for engine oil and tranny oil. My '73 has 88,000 miles. I'd like to say thank you in advance. Thanks, Roger Get into it ,I always change oil with a new purchase,a good 20/50 Dino engine oil is best,the trans is 80/90 hypoid gear oil,cheers. |
Frankvw |
working on my first 914 ! ![]() ![]() ![]() Group: Members Posts: 653 Joined: 13-April 16 From: Holland, the Netherlands Member No.: 19,896 Region Association: Europe ![]() |
oil type can be different if you are in another climate, so I can only say what I use in my aircooled VWs and 914 in the Netherlands. I use 20W50 motoroil all year. We have a brand called Kroon over here, they have a specific 20W50 for classic cars.
914sgofast2 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 732 Joined: 10-May 13 From: El Dorado Hills, CA Member No.: 15,855 Region Association: None ![]() |
For motor oil I use Valvoline VR-1 in the 20w-50 weight or Shell Rotella 20w-50; mostly because they have a high level of ZDDP that flat tappet cam engines need. For the trans any 80w-90 gear oil.
StarBear |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,162 Joined: 2-September 09 From: NJ Member No.: 10,753 Region Association: North East States ![]() ![]() |
Yes, high-zinc for motor oil. I use Penn-1 @ 20-50W. There's another brand I've used in the past, but can't remember it (nor what I had for dinner last night, so not surprising...)
porschetub |
Yes high zinc ,forgot to mention that,I run Penrite HPR 30 which is a full zinc 20/50 replacement,its easy for me to buy locally and often discounted which is good because isn't a cheap oil.
JamesM |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,100 Joined: 6-April 06 From: Kearns, UT Member No.: 5,834 Region Association: Intermountain Region ![]() |
I find most off the shelf oil is constantly changing and can be hit or miss. The oil you bought a couple years ago may be a different formula than what you pick up today.
Recently on all my air cooled stuff I have been running Joe Gibbs DT50. Its not cheap but its the only oil i know designed specifically for these motors. Trans gets the cheapest 80w90 I can find. I actually find the cheaper ones often work better as the syncros prefer the least amount of friction modifiers you can get. They need to drag or you wind up grinding gears. |
914 RZ-1 |
Porsche Padawan ![]() ![]() ![]() Group: Members Posts: 684 Joined: 17-December 14 From: Santa Clarita, CA Member No.: 18,230 Region Association: Southern California ![]() |
This is a contrary view from a blog (https://540ratblog.wordpress.com/):
In recent years there have been entirely too many wiped cam lobes and ruined lifter failures in traditional American flat tappet engines, even though a variety of well respected brand name parts were typically used. These failures involved people using various high zinc oils, various high zinc Break-In oils, various Diesel oils, and various oils with aftermarket zinc additives added to the oil. They believed that any high zinc oil concoction is all they needed for wear protection during flat tappet engine break-in and after break-in. But, all of those failures have proven over and over again, that their belief in high zinc was nothing more than a MYTH, just as my test data has shown. A high level of zinc/phos is simply no guarantee of providing sufficient wear protection. And to make matters even worse, excessively high levels of zinc/phos can actually “cause” DAMAGE your engine, rather than “prevent” it. Motor Oil Industry testing has found that motor oils with more than 1,400 ppm ZDDP, INCREASED long-term wear. And it was also found that motor oils with more than 2,000 ppm ZDDP started attacking the grain boundaries in the iron, resulting in camshaft spalling (pitting and flaking). The ZDDP value is simply the average of the zinc and the phosphorus values, then rounded down to the nearest 100 ppm (parts per million). From those failures where I was able to find out what specific oils were used, it turned out that those were oils I had already performed my Engineering Wear Protection Capability tests on. And all those oils had only provided poor wear protection capability, meaning that if they had looked at my test data before using those oils, they would have known in advance that their engines would be at significant risk of failure with those oils. And that is just what happened. A number of people who have had those failures, and some had repeated failures, have contacted me, asking what they can do to prevent that failure in the future. I tell them to forget all that high zinc nonsense and look at my Wear Protection Ranking List. And to select any high ranking oil there, no matter how much zinc it has, because zinc quantity simply does NOT matter. The only thing that matters regarding wear protection, is the psi value each oil can produce in my testing. The higher the psi value, the better the wear protection. I recommend they use the SAME highly ranked oil for break-in and after break-in. It’s that simple. WHEN PEOPLE HAVE TAKEN THAT ADVICE, NOT ONE PERSON HAS EVER COME BACK TO ME TO REPORT THAT MY RANKING LIST DID NOT WORK FOR THEM. Since my ranking list has worked in every case to prevent wiped flat tappet lobes and lifters, it can also work for you to provide the best possible wear protection for your engine. My test data is the real deal, it exactly matches real world experience, and it is the best and most complete motor oil comparison data you will ever find anywhere. And for those people who have been able to use various high zinc oils without having trouble with their flat tappet engines, that only means that the oil they used had enough wear protection capability for the loads their engines saw at that time. It does not mean they were necessarily using a great oil. And it does not provide any information about how much reserve wear protection capability their oil provided, nor how their oil compares to other oils on the market. But, there are some high zinc oils that do provide excellent wear protection. And you can see which ones they are, by looking at my ranking list below. |
Lo-Fi Version | Time is now: 8th July 2025 - 10:50 AM |
