Air/Fuel mixture gauge, To install, or leave it out? |
HansJan |
Apr 30 2020, 08:53 PM
Member Group: Members Posts: 395 Joined: 5-April 16 From: Sugar Land TX Member No.: 19,860 Region Association: Southwest Region |
Will an A/F gauge make me happier, or will it drive me nuts?
The 914 is carburated, and it runs great. But still have explosions in the tail-pipe when engine breaking. To add to the drama, 90% of these tail-pipe explosions occur under freeway-overpasses. Whats the verdict on the Gauge Yes or No? Thanks in advance. |
yeahmag |
May 25 2020, 10:43 PM
Advanced Member Group: Members Posts: 2,422 Joined: 18-April 05 From: Pasadena, CA Member No.: 3,946 Region Association: Southern California |
If you are on E10 you are looking for around 12.5:1 under load. If you are on E0 (pure gas) 13.5:1. Your idle is way too lean and with a 70 idle jet I suspect a false reading. Where is the O2 sensor installed?
The 155 is closer, but you can probably drop down to a 150. |
Lo-Fi Version | Time is now: 27th May 2024 - 07:25 AM |
