Fiberglass Sheridan front end - P 7 /8, Now done will have body in white soon! |
Mikey914 |
May 2 2020, 12:57 AM
The rubber man Group: Members Posts: 12,625 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
So we have the molds and are cleaning them. We did not get the substructure molds and are making them now. we are looking to pull a set in fiberglass and carbon fiber.
we will have the options to add balsa just like the GT hoods. Option for headlight delete hoods will be available for both. I will post more as we move along, but we will need to do some repair work on the molds to get to the point we can pull parts. we will then figure out how much they cost to make. Planning to run 10 sets at a large discount to launch these. Number sill follow So who's interested at least for now? |
pete000 |
May 31 2020, 06:38 PM
Senior Member Group: Members Posts: 1,885 Joined: 23-August 10 From: Bradenton Florida Member No.: 12,094 Region Association: South East States |
Would be interested in knowing the actual weight comparisons between stock steel lids, fiberglass lids, and the carbon lids. Also will it be a true bolt on configuration requiring no hood pins? I would imagine the carbon lids will be much stiffer than the Fiberglass units.
Are you going to vacuum bag the carbon? One last thing, it would be cool if you were able to put some yellow die in the resin for that aged OE GT look on the underside. Depending on all the above I would be interested in a set. |
Lo-Fi Version | Time is now: 29th March 2024 - 06:00 AM |
