Beater 2316, Deck height vs. CR |
groot |
May 2 2020, 01:15 PM
Dis member Group: Members Posts: 896 Joined: 17-December 03 From: Michigan Member No.: 1,444 |
So, finally getting around to building a "beater" engine to develop my race car project (been idle too long). The idea is to build a reliable, decent engine that's not crazy expensive to sort out my car, then put in the expensive engine when the chassis is ready. I will only use race fuel with this engine.
Basic specs are:
Now, the question... should I source 0.220" or larger shims to drop the CR at the expense of deck height? A shim of 0.220" will drop the CR to 10.4:1, but raises the deck height to 0.050" Thoughts? |
groot |
May 16 2020, 06:56 AM
Crazy stuff... about that sealed case.... Interesting, for sure.
Yes, I still have that pump. I've also modified a CB and I'll run them back to back on this engine, to isolate the pressure issue on the race engine, before I open it up to sort it out. |
Lo-Fi Version | Time is now: 21st May 2024 - 09:38 AM |
